- Dec 16, 2016
Hi Dom, Thanks. Hopefully when the weather improves you’ll get a chance to pop by, there’s always tea at the ready, you’d be welcome. The wood is all pear, I used a spirit stain and Ronseal satin poly varnish, I find that this combo always works well. I too don’t overly like cyno for the reason you state that’s why I stained and varnished the wood before I glued the batons so that I could wipe any cyno away and not get marking issues. Nice idea for dust prevention, I ended up using my spray booth extractor and a vac on my bench but using a sanding drum still throws dust up into the air, you wouldn’t believe just how much dust is created shaping the ribs, the outdoor solution was the only real option for me. KenHi Ken,
Just catching up with your build. It looks amazing, that's a lot of pieces to place so neatly! What type of wood is used for the framing? It looks really nice the way you have finished it, what type of stain/varnish did you use? Usually I avoid the CA glue because I find that stain doesn't take if it gets onto places where it shouldn't be (I can be a messy worker at times!) but then again, it is so much faster to use.
We will try to drop by sometime and say hello but the weather we have been having has been so rubbish we haven't ventured out to the Red rocks on our bikes for a while. Hopefully, the weather will improve.
Dom
