Good morning Marc. I have learned plenty from the input of Allan and Iutar while reading through the past few pages. Wow you are building a quality Diana. Kudos. Cheers Grant
Hello Grant,Good morning Marc. I have learned plenty from the input of Allan and Iutar while reading through the past few pages. Wow you are building a quality Diana. Kudos. Cheers Grant
Hello,The "Anatomy of the Ship" book by David White concerning Diana does not show a binnacle anywhere in the plans. Since I'm currently building this very same Caldercraft/Jotika model, I don't understand why a heavy frigate such as this would not have a binnacle in the very empty space between the wheel and the slightly trapezoidal hatch.
Hey Sal,Hi Marc,
I started the kit in September, and I'm currently just about ready to start the first planking. I've also completed all of the cannons, carronades, and deck fittings. I have about 2 more years to go at my present rate of working on this kit 3 hours per day.
Thank you for your very useful (to me) build log. Your model is looking very nice. Can't wait to see it finished.
Sal
Hello Mark! English binnacles, despite the general design, differed slightly in size on different ships. The main thing is that the height of the binnacle should be such that its top cover can be used as a table for working with nautical charts and instruments. Approximate dimensions of the binnacle in 1/64 scale: height 16 mm (approximately one meter, including legs and table top, but without pipe), length 26 mm, width 8 mm. Windows 5x4 mm. Count the drawers and window covers from the photographs.
View attachment 489673 View attachment 489674 View attachment 489675 View attachment 489677 View attachment 489678 View attachment 489679 View attachment 489680 View attachment 489681 View attachment 489682 View attachment 489683 View attachment 489684 View attachment 489685 View attachment 489686 View attachment 489687 View attachment 489688 View attachment 489689 View attachment 489690 View attachment 489691 View attachment 489692 View attachment 489693 View attachment 489694 View attachment 489698 View attachment 489696
Fly, there is some misunderstanding here (probably only on my part.) Why would you want the cavels away from the bulwark? I may be wrong, but the below sketch is how I believe they would have to look to work. If anyone has more information that would be great. There are examples of the two layouts on the left on the contemporary model photos above. I think sometimes there were cleats next to the cavel blocks for belaying rather than a timber head type shape.should be mounted at +- mm from the "wall"...because this space is needed for rigging cords.
As discussed in the past, it always a good idea to check everything before trying to fix it in place. By adding the spacing you pretty much accomplished the same thing as remaking new ones or carving away some wood on the ones that they provided. Good for you to catch this and fix it before you went to belay theBut for the Caldercraft rigging you need to glue the Cavels 1mm from the timber.
Thank's for the very positive rating!Looking beautiful Marc.
You are building a worthy vessel.
