Your binnacle and ships wheel both look great.
The whole build remains excellent and will be a source of guidance for me when I do my Diana.
Happy New Year to Marc.
I really like that you tied the binnacle down as was done back in the day. Nicely done!Am a (little) bit disappointed....
Nobody noticed my compass house....![]()
No lines ever passed through a plain hole. The wood and./or the line would wear very quickly, so yes, sheaves at the proper angle would be appropriate. Even the hawse holes had a lead lining to avoid wear on the wood.Should I also be provided with sheaves here?
Thx Allan,No lines ever passed through a plain hole. The wood and./or the line would wear very quickly, so yes, sheaves at the proper angle would be appropriate. Even the hawse holes had a lead lining to avoid wear on the wood.
Thx Allan,Fly (Vincent??)
In the end, if you are going to rig her, the line will cover most of the area from sight. When the sheave blocks were put into the real ship the frames were notched to hold them as they would otherwise be in the way as you mention. A simple set up can be seen below prior to planking.
Hey Iutarn
Both Allan and Iutar,
Dear Iutar,Dear Mark! When making scuppers on the deck, do not make holes in the waterway. Since the waterway was a power element of the structure, the scuppers were made in front of the waterway. David Antscherl is the author's contemporary and personal opinion; archival sources show the opposite.
Hi MarcInstead of gluing the round scruppers that came with the kit onto the Hull I worked something else out:
- purchase some 2mm diameter hollow tubes
- saw off 12 equal parts (5mm)
- paint them black
- make 2mm holes in the Hull at the designated place
- push them in and you're done...
And even if I say so myself it looks very nice...
Also started installing the deadeyes....lots of work...and precision required (work in progress)
See you soon
Marc
PS Iutar, see the eyebolts...
