**VIEW THREAD HERE** |
Hi Marc,Hello Mustafa!
How would you make the gun ports if the plans simply state that you have to draw the ports on the 1st planking and make the holes?
(unless I've misunderstood so far...)
To be honest I only had a quick look at the instructions when I purchased my kit a couple of years ago. I remember seeing that the gun ports had to be cut out, this is similar to my last model HMS Unicorn. I believe the Diana was one of the earlier Caldercraft designs the later ones used CNC cut plywood for the first planking around the gun ports. I was thinking of making a template to mark out the gun ports but until I start building I don't know for sure.Hey Tony,
Aan honor for me!
PS
I already see some serious challenges such as creating the gun ports. There is no special method provided in the kit other than drilling holes and tinkering until you get a nice gun port... I am considering making a frame like in the Con.
So how to find an accurate method for this...
I ran through this log and must say the finishing work is EXTREMELY neat. But, not everything is as it should be. Two examples that really pop out.......the planking looks to be like many kits, it does not all end at the rabbet but rather, five strakes come to a point against the side of the wales. There are stops in the tops of the ports as well as the sides and bottom but the stops were only on the bottom sill and on the sides, not the top sill.
Hi MarcHi Tony,
I am currently looking into the construction of the Hull. Such as the placement of the plank termination templates (20 & 21): no drawing is available... (just like the Stern counter frames etc..).
And indeed I still have to think about the gun ports, and as Mustafa said, not a too complicated construction.
As far as the plans are concerned, those of the Constitution are much clearer, but I'm not complaining...
On the other hand, I'm going to prepare the Keel with for example drilling holes etc...
Cheers
Regarding the knee of the head where you drilled the holes, did you taper it? (It is hard to tell from the photos) It is much easier to do this before assembling but can still be done now. The vast majority of kits ignore this major feature creating an overly thick knee at the seat of the figurehead causing it to look quite bowlegged. The drawing below gives dimensions for a 38 gun ship such as Diana (from David Steel's Elements and Practice of Naval Architecture)I first prepared the Keel as much as possible, such as drilling the 1.5mm holes for the bobstays as well as drawing the termination lines of the primary planking....
This is confusing (at least to meSomething I also noticed is that the kit does not include a false Keel at all, which is normally glued under the Keel to also provide a notch for the 1st planking...
With other words no extended tapering is required to allow the Hull planks to lay flat against the False Keel.
Hi MarcYesterday (evening) and today I neatly sawed out the Bulkheads and sanded them neatly and carefully, a la Tony.
You will notice that I will only chamfer them later, in other words after gluing the Bulkheads to prepare the 1st planking.
because I filed in the past often too much...
In any case, I first prepared the Keel as much as possible, such as drilling the 1.5mm holes for the bobstays as well as drawing the termination lines of the primary planking....
The I dry fitted all Bulkheads and the Deck (18)....some filing was necessary....
And then gluing the Bulkheads...something that used to cause me problems in the past. After all, even though I did everything I could to glue them neatly at right angles, I later found that it did not fit...
This time I glued the even numbered Bulkheads to the Keel and temporarily placed the Deck to be 100% sure everything fits...Judge for yourself...when everything dries I do the same for the odd numbered Bulkheads...
Cheers
Marc
I am enjoying your log very much Marc. You clearly have an eye for the details and this will help you and me in my build.Yesterday (evening) and today I neatly sawed out the Bulkheads and sanded them neatly and carefully, a la Tony.
Cheers
Marc
