Looks beautiful Marc. Bravo.
Way to go Marc. Are you going to include the netting? If so good luck and may much patience be bestowed upon thee..Before attaching the schrouds I thought it would be a good idea to install the Hammock Cranes first (for accessibility reasons)...No schrouds in the way...
And luckily (just in time) I noticed that the Cranes are not symmetrical...a part protrudes from the railing...
. Cheers GrantYes Allan, will add them..planned to do it when installing the shroud-gratings...Looking good Marc!
Is there a reason you left off the wooldings on the mizzen mast? Rope wooldings were introduced on the mizzen mast about 1773 and there were generally two less wooldings on the mizzen mast than on the foremast so would be appropriate for Diana 1794.
Hello Grant,Way to go Marc. Are you going to include the netting? If so good luck and may much patience be bestowed upon thee... Cheers Grant
The best coating for chariots and blocks, to try is with the cream used to clean shoes.Try it to believe.FrankShroud lanyards must be the same color as the shrouds and deadeyes. They were specially coated with quality pine tar to protect them from the harmful effects of water.
After seeing your comment I did some research on this and cannot find anything based on contemporary sources for British ships in the age of sail that state that the lanyards on deadeyes (and/or hearts) must always be tarred. Looking at contemporary models at Preble Hall, some of the lanyards are tarred and some are not tarred. Two that are not tarred can be seen in the photos below. This has been a subject of debate at times and I would love to find a source based on contemporary sources that states that the lanyards were tarred or not, or if it was one of those things that the boatswain decided so there was no established rule. Modern reproductions might not always serve as accurate examples.Shroud lanyards must be the same color as the shrouds and deadeyes. They were specially coated with quality pine tar to protect them from the harmful effects of water.
I have this information, sorry it is only in Italian language , translated from French.FrankAfter seeing your comment I did some research on this and cannot find anything based on contemporary sources for British ships in the age of sail that state that the lanyards on deadeyes (and/or hearts) must always be tarred. Looking at contemporary models at Preble Hall, some of the lanyards are tarred and some are not tarred. Two that are not tarred can be seen in the photos below. This has been a subject of debate at times and I would love to find a source based on contemporary sources that states that the lanyards were tarred or not, or if it was one of those things that the boatswain decided so there was no established rule. Modern reproductions might not always serve as accurate examples.
Many thanks IutarThis is described in all books on maritime practice in all countries,
with the utmost respect for YOUR opinion but, what I have as documents is pure reality, strange case that out of 580 texts I have there is no mention of tarring of “runners”.FrankMuseum models often show the rigging without protective covering. This is understandable, because the ropes became resinous after the final tension. There are many more examples with tarred rigging. It also happens that models are poorly restored or have modern rigging.
Many people remember the white ropes at Victory.
On the Victory ship, when she went to sea, the standing rigging was completely tarred. After previous repairs, they did not tighten the standing rigging on the ship so as not to break the dilapidated wood.
Since the rigging was covered with a protective layer only after tension, the ropes were left white on purpose. Today, proper restoration is being done, and the ropes are black again.
I followed with the biggest interest this discussion.with the utmost respect for YOUR opinion but, what I have as documents is pure reality, strange case that out of 580 texts I have there is no mention of tarring of “runners”.Frank
