WARNING: So my discouragement - I found a major problem - and that is that as you see in this first photo, the stairs that lead to the forecastle DO NOT meet to the Forecastle. I had a few choices to make, one was to just remove the Cannons on both sides and put the stairs where they belong. In other words, the cannons and stairs interfere greatly and can not occupy the same space.
Therefore, adding more woes and work, I decided to extend the forecastle deck on each side. The forecastle deck COULD NOT be extended all the way across as the fore-bitts would be covered up. So, this is strictly a patch, modification - not sure how to put it - but it DOES go against the plans.
Therefore here is the horror and my attempt to fix it to have the cannons and the stairs part of the build:
I then built a NEW FRAME that will hold the extension.
In order to make it look NOT like a major mistake, I had to rip out a few planks so that I could maintain a stagger of the deck.
And now this is where I am so far - when finished I have to do the other side of course. Then glue the cannon back in where I had removed it.
