HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
going further, better re-starting the interior works
not really in scale ;) but I decided to use here some "bolts" to fix the floor riders finally on the keel - here I did not trust the glue alone
In the kit 50 brass mortar shots are included
blackened they are looking more realistic
In reality these shots or shells had two handles / lifting lugs and a fuse hole ......
but when these shells are stored in the hold in the racks it will be hardly visible that the shells are are only round balls .....
Many Thanks for your interest .... to be continued .....
A secured base for those mortar shells, Uwe.
Bowling anyone? I never knew of lifting handles myself. And a beechwood fuse.....
Many Thanks to @RogerD , @Jimsky , @Mirek , @Keef , @GrantTyler , @profmomo , @Peter Voogt , @dnalley and @janos for your kind comments and replies and all others for the received likes - but in generalö to everybody reading my posts in this building logs -
Many Many thanks for your interest
....I had never heard of lifting handles/lugs so it’s time for me to do some homework :).
These shells were extremely heavy, so they could not be handled without such handles
maybe also interesting to read - excerpts from the Anatomy book by Goodwin
....is red Clou used?
Yes I am using on this model in general CLOU for the wood treatment
Bonjour Uweek, merci beaucoup pour ces détails. Je ne pensais pas que les boulets aient été aussi pesants. C'est pour cela qu'ils sont stockés en fond de cale.
Hello Uweek, thank you very much for these details. I didn't think the cannonballs were so heavy. This is why they are stored in the hold.
View attachment 429366 View attachment 429367
View attachment 429368 View attachment 429369
Thanks for providing this very interesting information Uwe. It’s fascinating to read the table showing the range of the various mortar shells.
Today I can show you the final works on the shall racks which have to be fixed, before I am able to install the bulkhead walls and the first lower decks
Only some more impressions together with the heavy beams, which have to be on top of the racks
this beam has to go appr. 1mm deaper
The next step was the sidewalls - and I realized, that I made an error when I finished the racks
the four wooden boards have to be between the base and the top - so I installed the small boards in which the shells are laying not correctly
in the sketch you can see how it would be correct
Two possibilities
- a complete disassembling - or
- maybe it is possible with some sanding ...... not correct aligned, but I was afraid, that with dissassembling I destroy more...
the other mortar base
and the back side, which will be completely closed
Now I can move fore, to install the bulkhead and the lower deck
Many thanks for your interest .....
Hi Uwek, How many plate "5A" was inside your KIT?? In mine was only one. I can bilt only one bullet case???
Two possibilities
Good morning Uwek. I concur with my fellow members. Impressive. Cheers Grant
Very good Job Uwe. One question. In my Kit N° 2 I have only one 5A. I cannot made 2 bullets store because I have not colums 5A for bilt the second one. Inside your box 2, how many 5A were??? because you have bilt 2 bullets store?
There were two of this sheet in the kit - but be aware, that this sheet has two "names" 5A and 4B
This photo I published in the kit review
If it is missing you have to contact Tom from CAF to get a second one.
