Hallo my friend,One question about the fit between the upper part on the lower part. It looks that on the stern and stem the wood is not fit right. Does the wood work or is it not just put in the right way together.
Thank you for the comment my friendThis is looking very good, Uwe. You are creating a once-in-a-lifetime model here!
Which therefore proves the point about being “half-cut”, which is informally interpreted in some countries as slightly intoxicatedNot necessary Jim a saw is a saw, but the HCAA club is that's when you f#@ked up your model and use an axe instead of a saw
Leave it like it is, 20 cm above nobody will notice indeed. Fixing it, I agree, sometimes you can make things more worse. I just wonder if the glue was the reason of the gap. Believe me, my HZ model is also not that correct like pictures sometimes show. There are a lot of imperfections.Defintely the upper part of the hull will be appr. 20cm above the lower half of the hull -> so never ever somebody can recognize it
I am afraid when I try, that I make it worse.....
DoneWell well, that's great!
Then I did that right away. If I can grant that freedom to myself...... Perhaps a tip for Maarten @Maarten ?
We are open to more registrations!
Hallo Christian, which beams do you mean? keep in mind, that I will present the model splitted, but I would like to respond and check your pointhave you tested how the upper parts fits at the beams? If I look to the photos I think that you will have there a small problem. The lower part of the beams are smaller the top.
This way of presnetation was only to remind to myself, how the parts would be located and work together before I start to fix them.So the mortars will stay with the bottom half and the top half will have two big holes?
It is looking really good Uwe. Those shot racks and the riders make an impressive structure. You can only imagine what that must have looked like in real lifegoing further, better re-starting the interior works
not really in scalebut I decided to use here some "bolts" to fix the floor riders finally on the keel - here I did not trust the glue alone
In the kit 50 brass mortar shots are included
blackened they are looking more realistic
In reality these shots or shells had two handles / lifting lugs and a fuse hole ......
but when these shells are stored in the hold in the racks it will be hardly visible that the shells are are only round balls .....
Many Thanks for your interest .... to be continued .....
Soooo good!going further, better re-starting the interior works
