HMS GRANADO - full hull - POF kit by CAF in 1:48 - by Uwe
One question about the fit between the upper part on the lower part. It looks that on the stern and stem the wood is not fit right. Does the wood work or is it not just put in the right way together.
Hallo my friend,
you are absolutely correct at the stern part - it is not fitting 100% only 99%
One reason is the still not adjusted planking at the stem which you can see at the older photo - the red arrows
and in addition, the green arrow is showing to the approximate location where some inner laying knees and also hanging knees are slightly hindering that both parts are fitting the last 1%
I was thinking about to adjust as much as possible, but in the next working steps
I have to add in addition internal walls which will be fixed in the lower hull, but have notches in the top (of the wall elements) which have to fit between the beams and carlings etc. of the upper part of the hull
=> This 100% perfection will be never possible, that all elements will fit - never ever - so I decided to stop adjusting the knees
Defintely the upper part of the hull will be appr. 20cm above the lower half of the hull -> so never ever somebody can recognize it
I am afraid when I try, that I make it worse.....
=> and I am ok with it, that you know it - it fits for 99% and this is ok, I think
Leave it like it is, 20 cm above nobody will notice indeed. Fixing it, I agree, sometimes you can make things more worse. I just wonder if the glue was the reason of the gap. Believe me, my HZ model is also not that correct like pictures sometimes show. There are a lot of imperfections.
OK - where did I loose the last 18 months?
It is already 18 months ago, that I prepared temporary some elements of the interior of the Granado
So I had two important recognitions
1) Time is running
2) It is good to make a regular building log, so you can take a look back in history in order check what you have made already - Hope to find all parts
Most important are the mortar beds and the mortar base structures (still only dry-fit)
Now I mark them and the order, so I know .....
and after some time I recoignized, that also at the internal planking some of the treenails are not nice - so - it was hammer-time
Many Thanks for your interest .... to be continued ......
Super, félicitations. Ca donne envie de se lancer sur ce projet.
Grandes félicitations. Cela me donne envie de me lancer dans ce projet.
Great, congratulations. It makes me want to get started on this project.
have you tested how the upper parts fits at the beams? If I look to the photos I think that you will have there a small problem. The lower part of the beams are smaller the top.
Hallo Christian, which beams do you mean? keep in mind, that I will present the model splitted, but I would like to respond and check your point
So the mortars will stay with the bottom half and the top half will have two big holes?
This way of presnetation was only to remind to myself, how the parts would be located and work together before I start to fix them.
I plan in moment, that the mortars with the wooden bases will be on the upper part of the model and only the beams on top of the mortar beam structure at the lower one
something like this shown with the arrows
red - upper part of the hull
green - lower part of the hull
somehow shown on the NMM-museum model - but I will leave the 2 times 6 heavy beams at the lower part
going further, better re-starting the interior works
not really in scale ;) but I decided to use here some "bolts" to fix the floor riders finally on the keel - here I did not trust the glue alone
In the kit 50 brass mortar shots are included
blackened they are looking more realistic
In reality these shots or shells had two handles / lifting lugs and a fuse hole ......
but when these shells are stored in the hold in the racks it will be hardly visible that the shells are are only round balls .....
Witaj
Zgadzam się z kolegami wszystko wygląda pięknie. Pozdrawiam Mirek
Hello
I agree with my colleagues, everything looks beautiful. Regards, Mirek
It is looking really good Uwe. Those shot racks and the riders make an impressive structure. You can only imagine what that must have looked like in real life
Soooo good!
