Good morning.I don't think so. Do you have a copy of Longridge's book? If so, see plan 9 (btwn pages 228 & 229). I was looking at the thimble in the Burton Pendant. I plan to put these on my cross section model even through there wont be running rigging to go through them. I want to install as much as may be practical on the yards and tops. I am also hoping that my rigging plan from the full model I built will help me with these as well. In 1/96, I am thinking about trying to take a 2mm dowel and use a fine file to cut a groove around the dowel every 2 mm or so. I would then cut off a 2mm-wide piece and drill a 0.5mm hole in the resulting disk creating a "thimble." If this doesn't work or hold up, I may just have to resort to making a loop using a. 0.5 mm drill bit.
Apologies - I used a metal ring to scale, a tiny dab of CA glue, wrapped the rope around and seized it tightly. I also gave a wood dowel a go but I could not get the scale right- kept coming out too big. I did not have any references when I built my Victory- it was my first modelling attempt….it was like references what are those
