- Sep 3, 2021
I'm impressed with your patience. I guess you'll need some more tries before you can declare succes though.Good morning- as promised the mouse. This is for the Main stay which is 1.5mm. Slightly out of scale. Ropes and sizes a discussion for another day.
The reasonable, bad and ugly..
These things are small. Using Grants maths this mouse to my scale is 3mm long, 3.5 at widest point.( Rounded UP).These will be tiny for the Mizzen top stay for sure.
Shaped using needle file from a 4mm dowel left over.
View attachment 315068View attachment 315069
Grants tips- what not to do
Get good thread- I did not have small enough so used cotton. It is too weak and creates explicit language.
Get the base shape correct! In my view one should exaggerate the pear shape on the base more as the weaving changes the shape. It also widens the mouse out of proportion. This May be Grants rookie skill level. (Is my 2nd attempt at a proper mouse- boy probably need 100 to get this right)
The longitudinal thread lines must be odd in number as this creates the basket weave pattern by just going over/under.
Don’t skip a line- pattern changes (I did a couple of times)
Have a good magnifying system(Grants eyes are good but not that good)
Don’t wrap the longitudinal thread tightly as when you get near the top (especially using cotton) it breaks when inserting needle- this is the UGLy..
I couldn’t follow Sasha ( @Alexander74 )steps completely as I served the stay up to the mouse previously and then will serve the balance after the mouse is on. (I did not have it in myself to redo the stay serving as well)I do see Sasha logic and it will be better to follow his advice. Next time Sasha
Never did I think.....attempt 2 and still not pear enough. I’m going to run with this and hopefully as I redo my Mizzen rats nest a mouse will appear more and more tidy. Still way better than how I made them previously.
Red arrow where the thread broke.
Some thread fuzz- flame will sort out. My biggest disappointment is the of shape- needs to be more pear shape in my view.
Cheers Grant
If I were to make these mice, the Dutch language would be enriched by quite a few new inventive expletives...
The fuzziness of ropes is a nuisance, to put it mildly. What worked for me were the various thicknesses and colors of Mantua rope, although they possess an unpleasant kind of "stiffness", causing poor handling characteristics, especially when doing ratlines, but they're definitely not fluffy.
