Hohenzollernmodell 1660-1670 Scale 1/75 POF build by Stephan Kertész (Steef66)
Thanks again for all the likes and visit to my log.
It goes a little more quicker with my new tool. And it is learning how to handle it, I can go to almost 95% of the sanding. Just a little part by hand now. You need to hold the Proxxon loosely in your hand and move it around a bit over the area to get a nice smooth result. I can hold a plank against the already sanded area to look if it is good, and yes it is straight. Almost halfway.
Part A will be the easy part, almost every frame is the same. And B will be the pain to make. But that I hear more people saying.
Enjoy the pictures of the result so far.
View attachment 453977View attachment 453978View attachment 453979View attachment 453980View attachment 453981View attachment 453982View attachment 453983View attachment 453984View attachment 453985View attachment 453986
A nice job, Stephan, with you new second hand tool. For sure you will find the right procedure for the other parts.
Mightily impressive, Steef, but I can’t wrap my head around the regular irregularities; I just can’t see the reason behind it, other than that you’re using whatever is available to you, like the old Dutch shipwrights. To me it’s like cursing in church, but nevertheless, together with @Maarten, you both are building unique models in terms of the followed building process.
Yup, and prove that it is possible to build a model in this way. And I use mostly scrap. My box with scrap pieces getting empty. Almost only a lot of tiny stuff and dust is in it. And the fun of do it in this way, later when the innerplanking (wegering) and outside planking is done, nobody will see this. But it will give me a strong hull where I can work with. Stronger then a POB build.
Hi Stephan,
Great progress on the hull.
What is your reason for all these small filler pieces? To have a stronger hull for your model?
These are additional to the ligger / buikstuk / oplang / steker setup.
No, I just forget to buy enough long curved beams. So I filled them up with shorter ones. Alien
When I make them out of one piece of wood the grain will be wrong on certain parts and that doesn't make the construction stronger. So yes, a stronger hull.
You bought the wrong trees :-)
You know a beam cut in two is less strong than a straight one ROTF
All about the money. Must be cheap. :cool:
Apart from a strength and stiffness point of view, I find a POF build more challenging and attractive than a POB build. No disrespect for those committed to POB builds. There are POB kits around I wouldn’t dare burn my fingers on…
POB is also faster and for a kit cheaper to produce. A 2 layer set is okay, you can make a beautiful hull with the second layer of planks. The challenge is my point to, that's why I try this way.
