My thanks to all as she is proceeding one day at a time as that is all that I have.Heinrich is right, she is processing swiftly and starts promising soon to be a looker!
While waiting for the glue to set on the second inner wale piece I went back to rough out an anchor for the boat:My thanks to all as she is proceeding one day at a time as that is all that I have.Rich
Adhesive set on both wide lower wales today:While waiting for the glue to set on the second inner wale piece I went back to rough out an anchor for the boat:
Sorry for the inverted research paper head.
Now I'll try for the anchor diagram taking those scaled dimensions in cm down to the 1:43 scale model size with the roughed out piece.
Now the recovered anchor tip piece:
They also recovered the lead weights which were in the cross arm but I will not include those.
Rich
Same procedure with a fix on the Port aft end which was not engaged with the frame.No assembly today, just cutting out parts associated with the instruction illustration for sanding and prep with stain.Adhesive set on both wide lower wales today:
One side view of the Stbd.
Nwale curvature:
Now setting the thin upper wale with a spacer shim:
And followed by the Port after Stbd was set:
View attachment 265607 Same procedure with a fix on the Port aft end which was not engaged with the frame.
Tomorrow will be a break to do some shaping of the anchor.
RIch
view of both interior wales:
After prepping the interior "structural" parts I have set them in place.She is looking very good Rich! When the rails go on, it will do wonders for the overall integrity of the look.
Thanks. It would be interesting to do a trial in seawater to see if the hook would be downwards or up when the cable would be slowly pulling it forward. Possibly there is enough wood in the main stock to have it floating above the lesser amount in the hook.I like your anchor!
Well, in my mind my log should reflect the realities of the days as to what actually occurs and not only the show pieces of my progress. Today shows little as on the side I had to scratch make a broken rail part where the kit did not cut out the small stantions squares which are very close to the edges and ends of the rail part. I used that as a template to trace onto some of the "spaces" between the laser cutouts to make a new one which shows the crude first cut on the bench in front of my placement of the first/stbd rail which was tied down and tensioned in place for the day to set:Looking great Rich! I love the wood colors!![]()
1-2-3 blocks with a lead piece provide the gravity which for this need is better than the morning tie-around which displaced the midships rail inwards.Still I think that you should consider the lead weigh which was found in the boat, which is regarded as a part of the anchor specifically to hold the anchor down.Thanks. It would be interesting to do a trial in seawater to see if the hook would be downwards or up when the cable would be slowly pulling it forward. Possibly there is enough wood in the main stock to have it floating above the lesser amount in the hook.
Yes, that paper was the one that I used and had posted upsidedown. My question is if the lead weight would have the beak pointing up or down during the descent. As I specuate more wood on the stock may float it above the beak holding it in the engaging position beak down. Once there the lead weight would certainly keep the cable end down and the cross arm holding it in most instances from rolling over. . . beak up. RichStill I think that you should consider the lead weigh which was found in the boat, which is regarded as a part of the anchor specifically to hold the anchor down.View attachment 266193
To satisfy Heinrich's interest in how the rails came our from under their setting load I found:THAT was the railing I was waiting for to go on! It is a major improvement and once the starboard side goes on, you will have a very nice integrated model - both in structure and as far as visual appeal goes.
Your father's concertina looks like a twenty button which is what mine is. I am only a stumbler and bumbler and not an expert but there is always hope in the futureMy father's concertina was an East German Gallotte. This today is one of my most prized possessions - it is with my son and looks and functions like the day it was made. Posing with it is my late Yorkshire Terrier, Rota.
Following setting of the first wale I prepped the stantions and had to drill two holes into the midships set for two lines passing between the fixed wood rails fore and aft. Here is the mini-vise jig to hold each for drilling:Your father's concertina looks like a twenty button which is what mine is. I am only a stumbler and bumbler and not an expert but there is always hope in the futureRich
Today was a lot of filing and aligning the fore deck stantions and railings so that the holes were aligned. Typically with kit laser cuts and build variations on the computerized perfect fit there were numerous adjustments needed. Once done I installed the port side first using spaces for the railings:Following setting of the first wale I prepped the stantions and had to drill two holes into the midships set for two lines passing between the fixed wood rails fore and aft. Here is the mini-vise jig to hold each for drilling:
Now we have the Port Wale in place completing that step along with the Stantions and wood rail pieces:
Next are bow and stern views of the wales alignments:
and on to a clear Stbd. elevation of the boat before setting the Stantions:
The lines wrap around the small inside longitudinal piece under the main railing (tomorrow)
Similar to the fore deck railings will be the longer aft railings with additional stantions and need to align everything.
