Not that much different to show with the installation of the after-deck stanchions (I finally looked up the spelling) and railings. then did a dry loose set of the midships stanchions with the ropes. I will remove these until after I have completed the mast shrouds to the lower thimbles (primitive deadeye function). So the mast and yard are next on the docket leading to the sail.Looking more complete all the time Rich. Nice to see you making such good progress.
Here is the Stbd elevation with bow to the right:
And tied off the lower thimbles beneath the cap railing to the small longitudinal piece below. Port side shown:
Disregard the loose stanchion lines as they will be drawn taught at final installation. The kit pieces did not extend past the stanchion far enough for a drilled hole to secure those ends so I will splice them around the fixed stanchions.
Her is what the reconstructed Kryenia looks like for those ends. (Photo thanks to Mensis)
This is the after end of the rope lines and you can see the connection to the after rails on the left. I should have looked at this and the fore end before using the kit cut parts and made my own to better serve the connection purpose. Maybe there is another Kyrenia build across the horizon as the present one will be given away and the recipients will never know the difference.
Mast and yard next.
... this site is like an online university for ship building.
