After a long delay and much thought, it's time to get working on the ship model again.  The block pendants and the eyebolts that attach them to the tops for various lines were made for the foremast top.  First, the blocks had to be prepared.  The blocks from the kit come with sharp edges and needed to be reshaped into more rounded and realistic shapes by rounding the sharp edges off with the Block Buster from ModelExpo, which is basically a plastic cup with lid that has 100 grit sandpaper on the inside surfaces.  You put the blocks in, attach the shaft for the internal flapper of the Block Buster to a portable drill, and spin the flapper inside the cup, which you hold with your other hand.  It's like a rock polishing tumbler for blocks.  After spinning the flapper at slow to moderate speed for about 30 seconds, you open the cup and dump out your nicely reshaped blocks and a bit of sawdust.  The blocks were then stained with a red-brown stain to give them a rich color.
The pendants were made by taking a length of 0.045" dark brown line and gluing it around the block on one end and feeding the other through a blackened laser etched eyebolt.  PVA glue was used to hold the loop of line together at the center, and a cheap Chinese serving jig was used to wrap the pendant with 0.008" diameter dark brown line.  The serving was tied at the block end with an overhand knot secured with a touch of PVA glue, then more PVA was applied to the line of the pendant.  The jig was then used to slowly rotate the pendant which keeping tension on the serving line with your other hand.  When the serving approached the eye of the eyebolt, it was secured with a simple reverse turn of the line, then the end was trimmed off.  The glue holds the line assembly together.
A total of five pendants were made.  The two in front included an eyebolts attached to the ends of 4mm blocks, and are for the foremast's course yard lift lines.  Two at the rear of the top are 5mm blocks for the hoist tackle lines used for general lifting and hoisting the pinnace off it's cradle.  The fifth is for the block that the main topmast stay passes through and is attached to the rear of the top.  The shafts of the eyebolts were CA glued into hand drilled holes.  For the eyebolts attached to the crosstrees, the shafts of the eyebolts were bent in outboard direction like a turn nail for extra strength.  The tip of a razor knife was used to cut a tint slot into the top of the crosstrees to accept each bent over portion of the eyebolt, so they would not protrude above the surface of the wood.  The top itself will glued to the trestle tree after all blocks and pendants for rigging in the area of the of have been installed.  This will take some thought, since the Corel model was not meant to include sails, and more eyebolts and blocks may have to installed than the instructions call for, especially if some more lines and details are added to the model.
A couple errors had to be corrected for the fore and main fiferails.  The holes to simulate the sheaves in the fore fiferail needed improvement.  A square needle file was used to open and shape the hole, and a small flat piece of wood was glued into the holes to divide them into two holes, simulating two sheaves in each side.  The tops of the vertical members for both fore and main fiferails were cut too short to tie lines to easily so more wood was added to form the bitts on top.  The holes in the fore knight are a bit sloppy, but at this scale, they won't be that noticeable once the lined for the tackles for the yard ties are installed.  The next ship will be easier since it's larger.
