Very good work - and I realized in your following post, that you made these notches afterwards.And now I realised I forgot something, these holes....
I think I can still clamp the entire piece in de milling machine..., we'll see...
Hello Uwe, yes, these details won't be visible at all. But I guess that will be the case with many parts to come, so I will try to follow the original instruction. It suit's my goal, to improve my skills...Very good work - and I realized in your following post, that you made these notches afterwards.
I guess later on they are not visible anymore, due to the fact, that the frames are sitting on top, and in real life inside these notches .....
take a look here:If anyone knows a better method for making the ribs I'd love to hear it! Apart from the bow and stern I still have 69 to go....
Hi Stefan, thank you for your reply and kind words! I looked at the report you mentioned, thank you for thistake a look here:
They make a rough drawing for frames and using glass plates to glue them straight. Also they make the frames with a big oversize to make sure after cutting and sanding the end product is straight and looking good. I see this:Oliver Cromwell, POF ,Scale 1:48 by Lawrence [COMPLETED BUILD]
Hello Ship Mates Here is a rather fun picture that I wanted to share with my Ship Mates. This is the package that my Oliver Cromwell building board from the Lumberyard came in along with the building board, and 4 Pear carving blocks came in. I have never seen so many stamps applied to a...shipsofscale.com
And when you planning an open side to see the inner parts, the inside needs as much attention as the outside. For a fully planked ship this isn't a problem but in your case it could keep you awake
Maybe you can ask them if there is a pdf for the rough drawings. I seen a discussion about it but can't find it back.
Hopefully I gave you a good advice, I'm not for real an expert in this kind of building. I just reaing a lot of build logs.
You are building a great ship. And you're brave doing this with so less experience in this way of building. Hope you get some good advice from the experts here.
I checked my board if it has the correct width, and I discovered something strange in the drawings. I guess I don't read the plan's correctly, maybe someone knows what is going on?It is still a bit tight here, I suspect that the building board is a bit too tight, but I still have to check that.
I have to say I am rather embarrassed.... I immediately checked your prognosis and you are totally correct...I may be mistaken, but it seems to me that you have a plan of the gun deck second from below, quarterdeck. The frames naturally taper towards the top of the body. On the frames, apply the lines of the decks and everything should come together.
I think you mean does happen.Do not scold yourself too much. It doesn't happen to anyone.
I know what you mean, моя жена русская , so we have also russian friends, I know automatic translators to russian are truly terrible...Yes, I wanted to say that this happens to many people. Difficulties of the automatic translator. Sometimes it is not possible to convey your idea correctly to the interlocutor.
