@Jimsky - I am glad this is helpful!
Please let me continue.
We now have the starting and end points for the planking bands only drawn at the very stern and the very bow. There are no points plotted along the length of the hull. Please remember that we have drawn the upper and lower edge of the main wales along the entire hull by joining the dots with a a pencil line and a thin piece of flexible plastic.
This line must be checked to ensure it is absolutely smooth from all angles before proceeding as it will become a reference line moving forward. You may need to erase parts of this line and re-draw it to ensure it is perfectly smooth.
We will now endeavour to draw the planking bands along the entire hull.
The attached image shows how I break up the hull planking in to 3 distinct sections: A, B and C.
Strictly there is no definitive point where each section starts and ends. Section C deals with the bending of the bands at the very bow and I treat this as a section in itself because I will not follow the rules I apply for sections A and B. Strictly, on my particular model, I don't actually need a section A as there are no stealers and the rules and logic I apply in Section A will be the same as Section B. I have included Section A because if I did have stealers I would do things in this section A slightly differently.
Starting at the thickest part of the hull (which is a particular junction of two frames) I measure the distance x very carefully (please refer to HullSection.jpg). This is the distance from the keel to the bottom of the main wales. At this frame junction count the number of hull planks that will intersect the distance x which is read directly from the plans.
My measurements were:
Distance x = 177mm
Number of planks = 23
Since I want to ensure that all 23 planks have an equal width at this point, I divide the value of x (177mm) by 23 giving a plank width of 7.7mm.
Now it is easy: one of my bands has 4 planks so the width of this band (at this frame junction) will be 7.7 x 4 = 30.8mm
Transfer this measurement of 30.8 by marking two dots on to a piece of paper (I actually use a thin piece of plastic) and use this to measure up from the bottom of the main wales (which remember have already been drawn in full) and place a dot on to the hull exactly 30.8mm from the bottom of the main wales. (Please refer to images MarkPoints.jpg and TransfertoHull.jpg)
Now simply repeat this process for the remaining bands at the point (frame junction) along the hull bearing in mind that one of the bands has only 3 planks and will therefore only be 3 x 7.7mm = 23mm wide. Since most of my bands are 4 planks wide I can use the same piece of paper with the 2 dots to repeat the process quickly at this same frame junction.
You need to repeat this process (measuring the value of x and re-calculating the width of the planks and then the bands) at every frame on the model for the entirety of Section B and (in my case) Section A because there are no stealers. *** You could do this every 2 or even 3 frames saving time but I like the accuracy of doing it at every frame ***
As you move backwards or forward along the hull the value of x will change. In my case the number of planks is always 23 until I get to the very bow (Section C) which I will discuss later.
You will now have a series of dots that delineate the planking bands from the very stern all the way to the intersection of bands B and C. Because (as I said earlier) the intersection of sections B and C do not have a definitive point I stop at the point where the bow starts curving in quite dramatically.
I will discuss the planking bands in section C shortly.
