Ahh. That worked. Thank you Signet. I don't have a 3D printer yet, but maybe someday!!
Will ask @Philski Phill, as he just got his printerAhh. That worked. Thank you Signet. I don't have a 3D printer yet, but maybe someday!!
Hi, I will add some images of how to make sails correctly, Generally, you stay sail, most having a triangle form. then there are square sails- by far the biggest amount and finally, some stay square sails (between the fore and main mast; then between the main mast and mizzen.On to the sails. Sails are supplied with this kit, and they look good, to me. Two previous builds by Jack Aubrey here on SoS and GreatGalleons on MSW used the kit sails, so I thought I'd try them out. Olga made her own sails from scratch, BTW. I also considered, and am still considering, sails made by HiS in Czech Republic; these can come completely sewn (but without boltropes), and might be better than what I have or can do. I don't know. But I thought I at least try the kit ones first:
The kit sails have margins around the outside that are folded twice. The instructions say to put wire into the first fold, to help the sails conform to the correct shape, and then 1mm rope in the second fold. This shows the second fold:
I thought it a bit strange to have such thick rope folded within the seams, but liked the idea of wire, so ended up using 22 gauge dark annealed steel wire, about 0.7mm in diameter, and which is very soft, in only the last fold.
The instructions also show detailing for sewing the boltrope in place, which seems unique, hopefully accurate and appealing to me:
When cutting the sail outlines, most modelers use CA glue, but I found that Dritz Fray Check does a better job. It goes on easy, keeps fabric from fraying, but does not get too hard nor does it color the fabric like CA. I also tried iron-on adhesive strips to hold the folded seams tight:
The Heat-n-Bond Lite Sewable iron-on adhesive worked well some of the time, less well at others, especially when inserting the wire.
After bonding the first seam, I ironed the second prior to inserting the wire:
Having trouble with the iron-on adhesive when making the last fold with the wire, so mostly used Aleen's Fabric Fusion to secure the fold:
I then inserted reef points at this stage, and ironed them flat, then trimmed them to length, before gluing the boltrope partially in place prior to stitching:
The stitching of the bolt rope was done more-or-less according to the plans above:
The stitches go over the inserted steel wire in the sail fold and over the boltrope, so it's quite secure that way. The stitch pattern appeals to me, and is hopefully accurate. You can see drops of the Fabric Fusion where the reef points were inserted, but these aren't very visible at normal distance. I originally thought they should be at the seams for strength, so put drops of glue there, but realized that apparently the reef points are at the center of sail panels.
I made the boltrope continuous around the outside of the sail. I started at the top mid-point, as I felt the rope seam would be least visible behind the mast and parrel.
The front of the completed sail (the foresail on this model):
and the back:
I don't much like the lapped seam around the back, as I don't think it's very accurate, but I've also seen many models done this way, including the two Carrack builds mentioned above.
Of course the soft steel wire is an advantage in shaping the sail the way you want to:
I still intend to make a mount for the sail and use sand in bags and potato starch to better form the sail, but the wire should help maintain the desired shape.
All in all, I think the sail looks okay, but probably not really accurate, with the large seam on the back. Making it better than that would require not using any stiffening wire, and I think I really like the idea of that wire. We'll see.
As this kit did not include the bonaventure sail I intend to include, I also had to make a new sail for it. Here, I've used a scrap portion of the sail cloth included to lay out and stitch the bonaventure sail:
Here the included Mizzen sail is at the top, and my new bonaventure sail at the bottom. The thread color matches fairly well, but the sails were stitched with a thread that is much shinier than what I used. I actually prefer my thread, but that won't happen unless I remake everything, which I doubt is necessary.
I need to now decide if the sail above is good enough for me, or if I want to order new sails from HiS, or even make new ones from scratch (probably using darker material, if I did). As always, suggestions and thoughts are welcomed concerning this.
those stitches are from me- El Capi. To add the Bold Rope is hell.happy new yearVery nice work, Signet. I am always impressed by the work on the rigging.
While I am sure that this information is correct, I believe it to be what was done in later years, and especially for British and western Continental ships. Stay square sails did not even exist in the 16th century, the time of this ship, nor did many of the other details shown on those drawings, and I have it on good authority from the researcher that the stitching on Ragusian and Dalmatian ships of the 16th century were done as outlined in the instructions above (and repeated here):Hi, I will add some images of how to make sails correctly, Generally, you stay sail, most having a triangle form. then there are square sails- by far the biggest amount and finally, some stay square sails (between the fore and main mast; then between the main mast and mizzen.
pay special attention to "how the Bold rope" is sewed by hand
That is a good idea. I had thought previously about placing small clamps to keep it in place.On the other hand, the sails do not look bad. When adding the boltrope to the edge of the sails, I said it fast with paper clips, before the stitching
When using Potato Starch the water must be ISCOLD. The rest is OKOh, I also tried a running a running lacing on the foresail, which I thought looked neat and would be easier to do that a bunch of robands:
It was a failure for me. I just couldn't get the stitching right and taut and looking good, despite how easy it looks (and must be). In any event, it was not saving me any time, so went with the more common robands.
Olha's videos, and how I've used it, is to boil water, mix the starch with a bit of water separately, then add it to the boiling water, continuing boiling while using, which in general, works great. The only problem I had was if the added/mixed starch was too thick, or added too fast, it would separate into clumps or sink to the bottom as a layer. I'd not seen it used cold.When using Potato Starch the water must be ISCOLD. The rest is OK
REMEMBER THAT WITHOUT FAILURE YOU WILL NEVER LEARN.
