I certainly wouldn't attempt to shape it with a blade as suggested. How about some sandpaper glued to a dowel of the proper diameter? Or a drum/spindle sander if you have one?Another small assembly that requires quite a bit of work. Pavel's video #34 ( Helm Port ) shows what is involved.
I haven't worked up the courage to tackle shaping the part. Maybe later this week.
I‘ve looking at drum sanders that would work in my Drill Press. Seriously I’m not to sure how to tackle this bit.I certainly wouldn't attempt to shape it with a blade as suggested. How about some sandpaper glued to a dowel of the proper diameter? Or a drum/spindle sander if you have one?
I certainly think this would be safer and more controlled than attempting that curved shape with an XActo blade. But don't underestimate the effectiveness of sandpaper glued to a dowel (free vs purchasing drum sanders - unless you wanted drum sanders anyway). Or maybe you have a curved rasp or file in your tool shed? It's hard to see how big this part is vs the size of the drum sanders...
Hi Ron.Nice fit-ups Jan. Looks as though you made it through the recent weather ok.
+1 for the spindle sander.
Ron
I think I‘ll order the spindle set from Amazon and give this a go. Besides if my boys spy a new tool in the shop they will immediately need it. I had a tough time hanging onto my new airbrush kit this weekend.Just finished planking this Steam Dome for a project I'm working on. The core is a 1-3/8 " diameter piece of balsa that I used my spindle sander to concave before planking I the used a dowel wrapped in sandpaper to sand the planking.
Sorry for the shadow
Similar dia.View attachment 356039 to what you're working with.
Good advice, I think It will a combination of both. Roughing in with the spindle and then the fine hand sanding. There sure is a lot of sanding dust involved with this build.I like @dockattner Paul's idea for the simple reason that even though it will be slower than the spindle sander, it will be very accurate with less of a chance of taking away too much wood at once. Obviously, if you have experience working with a spindle sander, it is a different story.
Thanks for the information. I’ll look that up.HI JAN, HAVE YOU LOOKED INTO THE WORKX SPINDEL SANDER, CHECK IT OUT, WORKS GREAT AND IT IS VARIABLE SPEED, USE MINE A LOTCOMES WITH DIFFERENT SIZ4E DRUMS. HOPE THIS HELPS. GOD BLESS STAY SAFE YOU AND YOURS DON
I wish you well on that endeavor Jan.This may be the start of having the finished Galleon displayed on the kitchen table. (I think Grant tried that ).![]()
