POF La Palme (L'Amarante) Corvette 1744 1:36 (Ancre Monograph) by Tobias
I like it very much - Bravo my friend
I guess the keelson visible in the lowest photo is not fixed, or? Otherwise it will hinder you during the final sanding......
Looking really very good :cool: clean and accurate in all aspects
Hello Uwe,
you see that correctly, the Kilson is not attached. The reason the kilson is in the picture is this: every frame has to be set up and every key between the keel and the kilson has to be adjusted, i.e. with every frame I add I take out the kilson and adjust everything. Very tedious but necessary to achieve a reasonably good result.
