thank you very much for your kind words my friend.Wow. I wasn't expecting that. Great work Shota. Do you have any experience in programming?
happy new year to you too my dear friendGood afternoon Shota. I hope the new year has started off wonderfully. Awesome work on your frames. Cheers Grant
thanks for your support and kind words, I will do my bestHi Shota. I appreciate your unique approach to leverage a skill you are strong in to accomplish your framing goals. As you know I value unique approaches.I look forward to each of your updates!
Good afternoon Shota. Those are fine looking frames. Many hours but worth it. Cheers GrantHello dear friends
In the last two weeks I continue to create the parts that required to create the frames.
The work is progressing at a somewhat slow pace, due to the need to create the drawing in the laser engraver software and the time required to cut a 4.5 mm thick wooden board. A single frame on its two layers takes almost 3 hours.
after that you need to sanding the black charcoal layer created by the Engraving process at the edge of the contours of the parts should be sanded. only after that you can start assembling the frames.
So far I have created about 10 complete frames in the current round and I have 4 more left to assemble. After that I will start sanding them to the angles that correspond to the outline of the ship.
I will attached pictures of the work process.
Your recommendation to use breathing and noise protection equipment has been fully implemented, don't be alarmed by the last picture
I wish you all a pleasant and enjoyable weekend
View attachment 420951View attachment 420952View attachment 420953View attachment 420955View attachment 420956View attachment 420957View attachment 420958
Looks very promising Shota! Happy sanding!
Hi Shota, nice progress, you're making good progress.
my dear friendsHello Shota,
Very nice work. You are making great progress.
Bill
you are absolutely right my friendDear Shota, nice progress on the frames. It must be very rewarding scratch building using/learning a new technique.
