Thanks Christian
The photo etched kit parts were first abraded on the reverse side to aid gluing BEFORE removing from the fret.Once removed, they were rolled to adopt the profile of the Beakhead frames, These were then metal primed, gloss black base coated then sprayed with Tamiya XF84. These have been put aside to fully harden before I will paint the recessed detail in blue acrylic.
I have now reached the stage where the stand has been revised to secure the hull in an inverted position.This model will remain this way until lower hull planking and rudder are complete.The underside will also have it's final finish applied before the hull goes back to being the "right" way up.
Kind Regards
Nigel
Kind Regards
Nigel
On some of the straight planking runs, I am getting some mileage in cutting the joins after fitting to save a little time.With the white there is not the colour variation that there would be say if I was using Pear veneer.
