Thanks it's quite a challenge at times.Dear Tony
you are doing wonderful work on this beautiful constitution
Hi MarcDear Tony,
I would like to ask for your advice (again). My next step is to make the bow. No laser-cut parts were supplied, so everything from scratch. An important detail is the decoration: it is supplied laser-cut, but with a very thin plate of wood.
Now I don't really know what to do with this. The decoration must be painted in white and then glued to the bow between 2 slats....
I don't dare cut them out directly from the supplied plywood as I am almost certain there will be damage.
I took a photocopy with the intention of cutting it out and glue it on plywood....after painting this paper white.... but almost impossible as the curves are so fine that I have not yet managed to cut them out so precisely....
Could you please take a look at this topic?
ThxGood job with an impossibly difficult Challenge!![]()
Thx "Just do it"......and with a little bit luck....wow. i didn't realize that one had to cut those decorations out. That material is very thin.
Good morning Marc. You certainly have plenty of luckand with a little bit luck.
Ok let's compete!First class work on the decorations. Let's see what I can do when I reach that stage.![]()
Nice! Did you use a scroll saw?Gentlemen,
Small update from the last days:
I finished the transom (see the stars...).
I glued the decoration on a black painted trailboard....
Then glued it in place on the stern: After all, it seems easier to me to make the cheek rails to size...
Cheers,
Marc
You might try a scalpel with a #11 blade....for your next project...Hello, No, I used my good old excel cutter....
The wood is very very thin and breaks very easily...
Marc
