- Oct 9, 2020
wow.I understand that there was, at one time, an Andrew Jackson figurehead which was somehow decapitated, disposed of, and replaced with the Fiddlehead commonly modeled today.
Hi thanks for the feedback I can see now the photo can be confusing. In the photo with the ruler the steps are in the channel after the filing had been done. The empty jig can be seen in the first photo.If I understand you correctly, you 3D printed the plastic step jig. The jig is in fact a set of plastic steps that you cut a channel into for the strip of wood, that's going to be cut to form the actual stairs, to fit into . A file was used to cut the steps into the wood guided by the the plastic steps in the jig. The screw and washer were used to scrape a round channel with the same radius as the bowsprit into the backside of the stairs. What's a little confusing, is the photo with the ruler. It shows the plastic jig without the channel but marked with gold tape or paint. I assume that photo was taken before the channel was formed. All in all, a very simple jig with great results. Great job. Now if I only had a 3D printer.
Thank you very much for the information. I'm confused because if you surf the internet you will find at least 5 different versions.... I'll just stick to the construction plan....Today, the Constitution’s guns are replicas, not originals. She hasn't had original guns since 1897. All of the present guns were cast for the 1927-1931 restoration with the exception of two 1812-era replica carronades on the after quarter deck. Those are 1808 pattern carronades cast in 1981 which are closer to Constitution‘s 1812 spar deck armament than the remaining 1840 pattern gunnades. You can spot the 1808 pattern carronades because they have a screw elevation mechanism to raise and lower the barrel as opposed to the wedge. Supposedly, the gunnades are to be replaced with the carronades some time a future restoration.
Tony,Hi
Firstly I would like to wish everyone a safe and happy Christmas it's a very special time of the year.
I finally made a start on the stern gallery at this stage I'm not sure how to complete it I'll try a few things out as I proceed.
I made a frame and used two dowels to hold it in place. At this stage I don't want to glue anything in place until I'm 100 % happy with it.
This is where the problems start the angels on the windows don't match. At this stage I'm thinking about making my own windows. I've seen lots of build logs with issues fitting the windows.
View attachment 415663View attachment 415664
I have added a few more pieces to get a better idea of what I want and how it's going to look. I need to make some changes, so this could be the first of many. If I have problems making my own window frames I'll try to make the kit ones fit. This is not going to be easy whichever way l choose.
Tony.
