ThanksAll set!![]()
ThanksAll set!![]()
Beautiful work!Hi
It's warming up down under and unfortunately I'm getting sidetracked and not spending much time in the shipyard. Since my last post I've completed the channels and mounted the deadeyes. This looked pretty straightforward but proved to be quite challenging.
I'm always worried about the channels braking off when I tighten up the shrouds so I added wooden dowels and supports.
I used a rope tied to the top of the mast to line up the chain plates
This is the problem I had with the chain plates, the PE holes are 0.45mm and the outside diameter is 1mm. Using the pins provided (0.6mm dia) and opening up the hole a little the chain plate split. In the end I purchased 0.5mm pins and opened the hole to 0.5mm. Another issue is the pins only go through the planks and do not hold the plates in place very well. If I was doing this again I would add reinforcing pieces under the planks where the pins go.
View attachment 487525View attachment 487524
Tony
Looking really nice. I like your idea of a backing for the chain links. I might do that before I put in my deck. Also possibly at the level of the channels as well.Hi
Tony
Good morning Tony. Brilliant. I really like the look and feel of your ship. It is realistic, giving an impression of a scaled down ship vs a model. @Jack Jäger is the master of this and you are following suite. So cool. Cheers GrantHi
Tony
Hi Thony, can these images help you? I hope to do a goodHi
Tony
Hello Tony, I lost track of your ship for a while. Glad I'm back on it and it is a beautiful ship indeed.Hi
Tony
Very fine work at scale, Tony!
Beautiful work!
Thanks for your feedback and complements they're very much appreciated.Amazing build!!
Thanks Grant, this is my first attempt at painting a hull. I'm pleased with the results but I think it's more luck than skill.Good morning Tony. Brilliant. I really like the look and feel of your ship. It is realistic, giving an impression of a scaled down ship vs a model. @Jack Jäger is the master of this and you are following suite. So cool. Cheers Grant
Thanks for the photos I especially like the older picture before the restoration.Hi Thony, can these images help you? I hope to do a good View attachment 487707
Thanks for the feedback, I'll be checking out some P.E. hooks for my next build.Nice work on the tiny blocks, Tony! No hooks seems like the proper call...
Thanks for the compliment, I used a standard red acrylic paint. For some reason my phone has a problem with this colour.Great craftsmanship Tony. I am curious about the shade of the red color though, mind you I am color challenged but it seems too bright.
Thanks, I am watching your progress, what a wonderful ship. One day I would love to include that amount of detail.Beautiful work Tony. Can I ask the size of the blocks? I will try to make my own too.
Thank you.Thanks, I am watching your progress, what a wonderful ship. One day I would love to include that amount of detail.
My blocks are around 3mm*2mm for the singles and 3mm*3mm for the doubles.
Tony
