Hey Donnie, if you can adjust the wheels for the saw, watch this video on band saw setup. It may help you with your bandsaw issues.Thank you Tony. I will consider. As I have to figure out with the tools I have. I wish I had a good scroll saw that could handle the size of the blocks.. I do have a table top 9” Bandsaw, but it is not working well as the blade keeps jumping off the upper and lower rollers. I also have a bench top scroll saw, but I will have to see if I have enough clearance between the platter and upper saw mechanism.
| Save the pieces from the first cut and use them as a "cradle." This will help make the next "complex" cut easier and keep things perpendicular. I used masking tape to keep them bound together until the cut was completed. |
| Water Lines (W.L. can be difficult to visualize and especially taken from the plans and transferring the pencil lines to the Blocks. It is easy to get confused (but after you do this, it starts to make sense - even to me !) I made these templates from the plans [ DETAILS 2-H on page 2] |
| All the Water Lines are now completed. |
This is a tricky part to do, reading the instructions I didn't realise the angle of the stern frame changes by 5 degrees along its length.The starboard side of Stern Frame is installed. The INSIDE (BETWEEN) width measurement between Frame #1 (outer) and Frame #2 are correct. The INSIDE (BETWEEN) width at the Bulkhead R is 9/16 inches. The INSIDE (BETWEEN) width at REAR TIPS is 3/8"
Even though the "PLAN" view of the Stern shows the Starboard Side as being flush with the counter, it will not look correct. Therefore a FILLER Piece will fill the Gap as shown in BLUE outline.
Also, the outer Frame has TWO (2) Bevels that will need shaping.
