USS Constitution MS2040
Such precision is unfathomable to an old 'just eyeball it' guy like me. :) :D
Looks nice. Reading through your log to see what is in store for me later this year when I hope to start on mine.
I have found that no matter how many ships (kits) a person has built (or at least this applies to me only - not sure), each one has its own quirks and challenges. With this ship, I have to relearn how to read plans and build most parts from scratch - as with this kit, you are given a box full of raw wood and some of it - not sure where or how some of it is supposed to be used. I have to suggest Bob Hunts Practicum on this one.
The booklet (not a manual) comes with it, but it has artistic hand-drawn illustrations that do not say much about which wood planks or strips to use. Again, you must refer only to the plans to figure things out.
Well, I was wondering why things were going along so smoothly - I screwed up MAJOR big time - but I am not so far ahead that it can not be corrected. I deleted all my post showing the installations of the port sill framing. I was supposed to use 1/8" spacing from the lower edge of the planksheer to the bottom edge of the upper sill. I did not use this spacing. I used 3/32 --- arggggg. So, what that means is that all the gun port frames will have to be moved DOWN some.
by some, I mean at least about 1/4" or more.
So, I had just finished all the planking around the gun ports, when I realized that something was not adding up. On the frikken plans, they only give the THICKNESS of 3/64 and not the WIDTH of the planks - this is a major error as far as I am concerned.
Time to get out the water (to soften glue) and start moving gun port frames downward. Crap !!!! Well, I guess it is a good thing I caught it now.
Oh sheesh! That is very frustrating (using polite words here :)). If I had done that, I might have ended up with a pile of small sticks and no one would come near me for a week. I'm sure you will overcome this setback in amazing style !
Mistakes, major or otherwise always come along. It is great to see when someone will not just let it go, but rather will go with a "do-over" to makes things right. You are to be admired for this.
Thanks guys. Yes, the repair (correction) is going nicely. I need to slow down more and study the plans and make 100% sure of what I am doing.
I was not anticipating that the WIDTH of the planking changes often. I think I got it now.
I am back in constructing where I am supposed to be—all ports on both sides had to be removed. It should have been obvious to me, but having tunnel vision, it escaped me. The ports were painted gray primer first, then black with acrylic. As a side note, the planking strips surrounding the ports will be painted white first before they are glued on. This keeps from having to mask off areas and should have a cleaner look.
The first image shows the gross mistake.
After much thinking (well, actually, not that much) comes the element of painting—when to paint, what to paint, etc. I don't really like building up the upper hull and ports and then coming back and trying to mask off everything.
So, my thought was to make each 'panel' that goes in between each port, 1) glue the side ends together being held by tape, 2) put in vise to dry, 3) sanding a little, then 4) paint with white.
In some research, I found that only the outside "surface" of the panel is white. All of the recesses of the Gun Port are black. So, some very fine painting still has to be done by hand.
So far, here are the results. I am hoping that this will pay off in the end. When completed, I will use some type of card stock and tape or something to tape across this "strip" of ports to protect from dings and what not.
I will soon show a series of pictures of how I am making each panel (the panel that goes between the ports).
This paint is from Hobby Lobby
Ivory Black
Titanium White
Supposed to be a Satin Finish
Very clean work, Donnie!
She is looking great ! And the painting is wonderful ! Nice even finish and great cover. As I was reading I was thinking I was going to ask you what paint you used, but you heard my question before I even asked it. :D Did you brush it on, or spray it with an airbrush?
In this situation, I used a brush. I am not too particular about the brush but just used what I had on hand which the bristles were about 3/16 wide and semi square at the end.
If I were building like a modern aircraft carrier, then I would use an airbrush as the plastic is not going to absorb the paint like wood does.
This is a step (after) I have cut each planked panel (in between each port). I have each section cut as best as I can,
1) then while the planked panel is on the ship, I will apply some tape to keep the planks in order.
2) Then I remove the panel as seen by the first photo (being held by the tape).
3) The good part comes is when since the planks are held in place with the tape, I can take my fingers and arch the assembly in place exposing the sides of the planks which I apply the glue.
4) I will then reposition the 4 planks back together while the tape continues to hold the planks in place until I place them in a vice - not over tightening the vice, but just to grab them until the glue dries which does not take long about less than 5 min.
The tape is still there in the second photo even though it is not seen due to fingers.
