**VIEW THREAD HERE** |
Mistakes, major or otherwise always come along. It is great to see when someone will not just let it go, but rather will go with a "do-over" to makes things right. You are to be admired for this.o, what that means is that all the gun port frames will have to be moved DOWN some.
Very clean work, Donnie!After much thinking (well, actually, not that much) comes the element of painting—when to paint, what to paint, etc. I don't really like building up the upper hull and ports and then coming back and trying to mask off everything.
So, my thought was to make each 'panel' that goes in between each port, 1) glue the side ends together being held by tape, 2) put in vise to dry, 3) sanding a little, then 4) paint with white.
In some research, I found that only the outside "surface" of the panel is white. All of the recesses of the Gun Port are black. So, some very fine painting still has to be done by hand.
So far, here are the results. I am hoping that this will pay off in the end. When completed, I will use some type of card stock and tape or something to tape across this "strip" of ports to protect from dings and what not.
I will soon show a series of pictures of how I am making each panel (the panel that goes between the ports).
