VOC ship The Prins Willem (scale 1:75) Year 1651
This is my next project these days. Need to make a hook with an eye for a block. At least it seems to be something like that. I got a picture of the museum model. (If anybody have High res pictures to send me, your welcome.)
I try the method of Bibigon (Sergey Trubchaninov) to achieve this
I will keep you updated if I succeed, or not :rolleyes: a lot of Coffee for sure
:) on the Russian site I found another example of Bibigon
That looks easier to do on a small hook.
I started with brass wire of 1 mm. in diameter. And the result after 2,5 hour (one hour to beat the carpet monster :confused: ).
I'm satisfy about it and 50% of the job is done, one more to come.
View attachment 401160View attachment 401161View attachment 401162
View attachment 401154View attachment 401155View attachment 401156View attachment 401157View attachment 401158View attachment 401159
WOW! JUST WOW!
#Trying to find my lower jaw in the carpet# Astonishing!
That is just ridiculously amazing, (translate that google) you are out of this worldAlien
Very good work on these hooks - I used also bibigons way for my hooks on the Le Coureur, but yours are looking much better ..... very good work
Paul , Johan, Richie, Jim and Uwe thanks for your compliments.
And thanks all for the many likes and visit to my log
@Uwek You try these:
I like to work with them. This is sandpaper in a small circle to attached on your Dremel or Proxxon drill. I also made a piece of thin plywood in the same shape to put behind the sandpaper when I need a strong surface. This works perfect to shape these tiny things. The other thing I use is Corradi Needle files, the smallest set you can get.
Back to my log I finished the backstays. (pardoens)
First the second block with hook, just took 1 hour this time.
Then I made 2 grommets, I use a piece of rope that I split up in 3 strands. From one strand I make a grommet and glue the last parts together.
Then I made the backstay
Extra ring on top of the block to fit the backstay to it
Here I make a coil of the remaining rope.
The finished backstays
Extra picture of the stay block and hook I made before.
Guess what, Shrouds and Ratlines are next :rolleyes:
Very nice and very fine work, Stephan. This must be very satisfying.
:) Thanks for the likes and the jokes.
The cleats are in place and the main topmast stay is done. Wow that was a lot of work. Making the mouse, the block with hook and the block on the top of the fore topmast to lead the stay down was a pain in ... to get that in place. But it is done and it looks good. Next are the back stays.
View attachment 400986View attachment 400987View attachment 400988View attachment 400989View attachment 400990View attachment 400991View attachment 400992View attachment 400993View attachment 400994View attachment 400995
Good morning Stephan. Shroud cleats are a pain in the butt….(well for me). Brilliantly done. Cheers Grant
