Dear Peter. This is not good news! I wish you the best and soonest recovery possible. Just remember that it does take time, so allow yourself ample time for that.
Get well soon Peter, hopefully before your holidays.
Thanks Heinrich, Maarten en Mark. Much appreciate!Recover soon Peter![]()
Very very wise words, Paul!I like your approach here Peter. We can becomes slaves to scale corrections and end up with something that is either not 'doable' or is unappealing esthetically. Choosing what looks right is the way to go, especially if the goal is home display. Great work as always - looking forward to seeing more of your beautiful work.
Indeed, wise words!Very very wise words, Paul!
Thanks, Johan. “To measure is to know, to see is to believe.” This way I can convince myself …….Your choice is esthetically appealing to ones eyes. Also when comparing the old pictures with your choice of deadeyes and ropes, I can't and won't dispute your decision making.
And as you already mentioned, going any smaller might also mean handling issues, especially at (y)our age.![]()
Of course I tested that, Stephan.Hope the .4 mm wire is strong enough to hold the shroud.
Very extensive work instructions.Started making the braces around the deadeyes.
Just took some pictures of the different stages and the tools.
Because everything is screwed together with the M0.6 bolt, I started clamping a 0.65 mm nail in the vice. The eyes that I make around it then have some space.
1: the eyes on the chainplates formed around the nail. They were made for the M0.8 bolts;
2: cut pieces of 19 mm from the 0.4 mm wire and twisted an eye on each side. The eyes pinched flat between the pliers to give the bolt and nut some 'flat meat' later on;
3: bend the bracket in radius with the round-point pliers;
4: bent around the 4 mm deadeye. Positioning the eyes with the toothpick in the right position;
5: picked the M0.6x5 bolt and nut;
6: screwed together and tensioned the deadeye in position. I first put the bolt through the 3 eyes. Set it upright and put the nut on the threaded end with the tweezers. With the cotton swab you can then apply pressure in a flat way and give the nut the first turns. Give you the first twist with the tweezers ..... big chance that you have to look for the nut somewhere .......... After the first turns, tighten further with the tweezers and cut off the protruding piece of threaded end. A little blackening and ......... tada.
It was a smart tip to work on a towel. Then the parts don't jump that far away.........
I'm going to prepare 20 pieces now.
Thank, Johan. While I'm figuring it out, I might as well share what a possibility is to make.Very extensive work instructions.
All too frequently I find myself browsing your build log, looking for tips and tricks. Luckily they can be found abundantly.![]()
Thanks, Mark. Do my best …….Very neat and tidy work Peter, it's going to be a beauty. It already is![]()
Thanks, Johan. With this parts, I think Eisnor is not right. So, if you like them, it’s up to you. But you have just installed the rails.With respect to the chainplates, I guess there's something to say for either option.
Since the YQ kit comes with slots in the bulwarks and monkeyrail, which are aligned such that the chainplates need to be near vertical, it's almost a moot point. Although, I would have loved to see how you would have made new rails with the chain plate slots relocated to match Eisnors' interpretation. I know you could...
Again, a pleasure to read your post and see the results of a rainy day spend at your office.
No way I'm going to re-do the rails!Thanks, Johan. With this parts, I think Eisnor is not right. So, if you like them, it’s up to you. But you have just installed the rails.
