Started customizing the frame for the Cabin under the deck beams, including the height:
Fitting under the beams:
To get a bit of a picture of everything, my iPhone crammed into the hull.
I will also use the theme that I used for the walls of the FishHold for the further building:
- the back wall has the nibbling planking from half;
- the port side has the wall coverings, 2 bunks and before that the bench with 'storage drawers';
- the starboard side remains open with the frame.
Dry-fit the frame of the deck beams again to fit:
The whole is located slightly inside the opening in the deck, but that has a reason because of the interior wall of the upper structure. It will slides in along the beams to the bottom frame.
With view through from the side:
The wall of the Cabin on the deck will also remain open to starboard so that you will also continue to have visibility when the BN has been completed.
Under de bench is no gap. It is the shadow of it, because of the light above.
Now finish the starboard side with the Captains Cabin, the frames for the bunks and the benches around.
