At least you partially know what you do not know but the what you do not know is unknowable until you arrive at that place when it becomes apparently knowable but still unknown. Your courage with the razor saw is intimidating!!!! Rich
That's quite a bit of known unknowns. Or.... is it the other way around?
I’m not sure I know what Rich is saying? ;)
They say a smart man knows what he doesn’t know. :p
If it weren't, it wouldn't be. That's how it is.
And you don't have to know everything, as long as you know someone who knows.
Its not about what you know and don't know, its about knowing when to ask about what you don't know.
For me I know just enough to be dangerous in my workshop, and don't know near as much as many senior members of this forum.
And sometimes, Kurt, don't ask but do. So I did with my saw. ROTF I did not know where it ended, but now I am here at this stage. But yes, it was also dangerous.
The advantage of skating at these Olympics is that they started with the 3000 for the women and the 5000 for the men. That takes a long time. I sat down in front of the TV with my stash of re-pointed toothpicks. And with the DrawPlate the treenail dots rotate. :) And now we have 1 Gold and 1Silver.First Place MetalFirst Place Metal
With the new stock of a few hundred, I was able to provide all the planks installed so far with the 'trennels':
Between the 2 blue arrows the next 12-frame plank that has to be sawn in half. With the intended saw seam.
But wouldn't I start sawing a half hull? Still, I wanted to try whether my first option of sawing per plank was also possible. Then you have a better view and direction of the already existing saw cut. Because in the first part I had lightly tapped a few frames with the saw. I do get that flat and neat again, but what doesn't need to be updated is always included.
Sawn the plank from 2 sides:
With the 'loose tip' feared by Johan @RDN1954. ;) But it was not loose and that stayed on the frame.
This has been 'roughly' sanded, so the treenails are not yet neatly flattened. That comes when the whole hull is closed.
Using the strip that I later apply to fill the saw seam and then equal the waterline-line, applied the following plank:
The tip, with glue on the sides, held in place.
So it can also be done this way.
Now just drill, place trennels, sand and on to the next cut.
The lines on the sides of the frames are from always calculating in between to see if I can manage with the rows of full planks.
I am so glad that that "non-loose" loose plank is now secured and no longer "loose". I breathed a sigh of relief - I don't know what you did.
Awesome Peter, I was really anxious about those loose (and vulnerable) tips, but it looks those fears were unfounded.
Top job!
