Kurt Konrath
Kurt Konrath
Working with the lathe on making more parts, your getting me to the point I need to spend my covid money on more tools.
I do not want to criticise you..... but you are absolutely right with your debate.This next part is debatable as even the AOTS Blandford book seems to have some discrepancies about the exact location. Mike calls for the pump to be located at station Frame #6 which if this is the case, then the output port of the pump will pass through the frame. The AOTS has the pump output port passing somewhat in-between frames. Which IF this is the case, then the pump will be located in such a manner that it will interfere with the hatchways and other things.
So, with that being said, I know I am going to get the criticisms as this part, I do not know much of what I am doing on this part.
Hi Donnie,Yep, you probably need to get one. I suggest Sherline, but others like the proxxon. Many on the market now to choose from. Even Micro-Mark has a 16" C-to-C as well as Harbor Freight.
Now, since the output port has a hole for water drainage, I had to use my 4-way adjustable chuck to hone in on the exact center of the square rod as the rod is an odd shape.
The paper template worked well as I did not have to do that much shaping, but I did want to have one continuous square rod to pass all the way through. So, I am ready for all the 'you did it wrong" comments. It is what it is.
So, there is no way in heck they punched a hole in the frame to let this pump port pass through. I guess in the long run, it WILL be covered up.
Abe books,Amazon,ebayDonnie, do you have a reference source where to order the AOTS of Blandford.
It would be a good read as I start the building when I get my frames done.
I would leave it also like it is now..... due to the change in the framing it will be not possible in a different way.OK, before I redo all of this, I am confused. The whole time I was doing this, I was thinking that passing the pump output through the frame was not right and not a good idea. So, should I leave it or redo it so pump port will pass in between frames? Please advise because I am leaning towards Uwe. The AOTS book does show it passing in-between. I have NOT done the other side yet. But, yet I also do not want to make any enemies here by favoring one person's idea over another.
But you should put your model on display - it is a very accurate and clean workUwe,
please, no need for apologies. Your criticism is exactly what I was needing and thinking about structural integrity. I accept your comments 100% open ----However, I have decided to just leave the matter at hand and press on to finish the build. All of this is just a learning exercise. The model will never make it on display anywhere other than my office or home. By that time, I would have moved on to another project with more issues to overcome !!!
