yes, thank you very muchHello Shota, Have you tried to click on the links that I posted the other day. I figured that they would be of a great help to you.
Regards Lawrence
Thank you very much dear friend,Magnificent craftsmanship.
Some day I’ll reach that level of expertise. LOL
Kurt, I don't think the razor blade would be a good tool for the above-mentioned job. the 'end-point' must be as round as possible otherwise when you will cut flush with the deck, the treenail will not be round. The sanding disk will be a far better tool. The idea should be similar to a pencil sharpener...One of the efficient ways is to use rotary tools. Tight toothpick in the chuck, turn ON, and touch the end with sandpaper. It will be perfectly round.OK, this may be a silly question but other than razor blade and sanding is there a tool to sharpen the end of toothpicks that have had ends cut off once so they can be reused over again until too short!
