Yes, you will need another set of beams for the cabin deck. Looking forward to seeing it come to fruition!Thanxs Dean, for thinking along. I visualized the structures on the deck and adapted my plan to them. The stairs run from back to front and then lead to the cabin. There are also level differences visible in the drawings in The Saga, so with AL-FI in it, I think my plan will fit.
It looks like the far wall is at the end of the fish hold, which I assume would be at the end of the mid lower deck beams. You can use the deck sheet to help locate the walls, that will give you the perimeter of the cabin. I’m sure you have figured this out. Also the deck beams should line up and locate them.This drawing in The Saga is helping with my plan:
There will be an intermediate floor later. So storage underneath it.
I can line out that sub-floor, when the frames are planked on the inside.
Yep Dean, when I start with the deck beams, I can line up the inside walls. But hope I will get my wood for the inside hull planking soon.It looks like the far wall is at the end of the fish hold, which I assume would be at the end of the mid lower deck beams. You can use the deck sheet to help locate the walls, that will give you the perimeter of the cabin. I’m sure you have figured this out. Also the deck beams should line up and locate them.![]()
Thanxs Heinrich. Fortunately, there is that drawing to give some direction. Hopefully that fits in with the rest of my plans.This is the first time in three days that I could access SOS. You have made great progress - the speculative investigations sure add to the suspense!![]()
Thanxs Heinrich. Rotating the jig/hull to see the alignment from different sides, I saw with the (warm) spotlight several nice shifting shadow effects between all those frames, beams and sticks. Too much to post.WOW That color is incredible and the overall effect, stunning!
I think Peter is having as much fun taking pictures of his ship, as he is building it!WOW That color is incredible and the overall effect, stunning!
You are right, Dean. Photography is now also a hobby, which I have been able to apply professionally through my work. And in which, still in the analogue era, I was able to learn a lot about the technical aspects.I think Peter is having as much fun taking pictures of his ship, as he is building it!![]()
Dear friendBefore I can start customizing the deck beams, the most important thing now is to align the top of the bearing beam properly. Because they ensure that the deck beams are lying horizontally and have a nice course of the sheer in the deck.
As with the subfloor, I align it with the long toothpicks:
In the bow it is very tricky, because there they are close to each other. Every fraction of a mm already gives an oblique position, as shown here.
After several times sanding, re-inserting and fitting, sanding etc, finally a satisfactory result:
Still not easy to make a straight picture with the iPhone through the small opening at the back.
With the overview:
The next step is to prepare the clamps, shown in the drawing from the Saga (see post #372).
That was a while ago, but for a number of steps in the construction of the hull, I sometimes have to think a several steps ahead. And only later I can apply it.
I can, of course, omit that thinking ahead and only show it when the time has come. But I just want to show in this build-log how the whole process goes. (But I don't want to spoil everything either.)
The deck beams are locked between the clamps, lying on top the bearing beam.
This clamp comes just above the bearing beam and rests on the cams of the lower rear frame parts. So I included the flattening of the cams when aligning the bearing beams:
Once I have the deck beams in place, I can flatten the clamp to the correct height. So that later the deck will lie flat over it again. Because of the chamfering of the deck beams towards the bow and stern, the height of the clamp is not the same over the entire length.
Time for scratch building of the clamps.
Thanxs for the compliment, Shota. I really appreciate that!Dear friend
you are doing wonderful work, very accurate, the result is great![]()
Thanxs Shota.well done dear friend, it's looks great![]()
Hi Dean. They where dry-fit. I can't install them until I've planked the (portside) inside of the frames. Starting at the (sisters) keelson and then up to the bearing beams of the lower floors. Then I can install them and then the planking further to the bearing beams of the deck.I realized you took out all of the lower crossbeams, as they were never installed permanently? Can’t you install them now?
Ok, that makes sense, I didn’t realize you were planking from the keelson up.Hi Dean. They where dry-fit. I can't install them until I've planked the (portside) inside of the frames. Starting at the (sisters) keelson and then up to the bearing beams of the lower floors. Then I can install them and then the planking further to the bearing beams of the deck.
I am waiting for delivery of the wood for the planking. Perhaps I will go to order by another shop.
