Thanxs Jan, I'm glad it turned in the right direction.Now that looks like the real deal.
Jan
Congratulations on this great success.And to top it all - South Africa has just beaten the British and Irish Lions 2-1 in the Test Series! Now I can go to sleep a happy man!![]()
Much better! And you don’t have to save nail heads anymore…Dean, thank you very much to set me sharp and on course. And thanks to @Steef66 Steef, in a big shop nearby (Action) for €0.79 I bought this:
With inside 3 different sizes of little stones.
Not the right color, but a hand full tumbled in a tube with some Steel-paint and let them dry:
Then tumbled with some of the glue and inserted:
Tomorrow after drying some better pictures. I am glad I have made this change.
THANXS GUYS!
You know I’m always looking to help!
Thanks, Dean and Henk.The stones look good and fit better
Good choice![]()
OOH, I like that. Looks just right.Dean, thank you very much to set me sharp and on course. And thanks to @Steef66 Steef, in a big shop nearby (Action) for €0.79 I bought this:
THANXS GUYS!
Thanxs Heinrich.In one word. superb!
Wow! I real nail bitter for sure...I wish you success my friend!A few members of the SoS knew about my plans. Inspired by the cut of @Maarten Maarten.
A BN as an “open waterline shipyard model”.
This means that the hull is cut at the waterline.
Here's what I mean:
With the advantage that you will also keep a view of all the work I now do on the inside of the hull.And the layout of the cabins and fish holds that I still want to make.
I have already marked out the waterline on the hull. A matter of securing the hull in the stand and marking it all around.
I was planning to only post about this when everything was over.But I would like you to enjoy the excitement and tension that this brings.
So here are some pictures from the beginning and how I approached it.
Until recently I didn't know when I would do this. When the whole hull was ready, for nth solidity?
Decided to do it now. Because now I can still reach the inside to make adjustments if necessary.
First I made a mold in which I could align the model exactly on the waterline:
I had already attached the YQ jig to the top plate, to get a firmer surface.
I have now secured it with threaded ends on a sturdy bottom plate.
In between I attached 2 aluminum profiles. The advantage of these profiles is that they are straight and sturdy.
All with washers and wing nuts so I could level the hull to the waterline. Both in length and width.
Then I could screw up both profiles so that they came to the waterline at cutting thickness:
At the front the waterline starts just below the lowest point of the 5th frame.
And at the rear it also starts just below the 5th frame from the back:
All can be found on the drawings of YQ.
There are some lines on the hull above and below the waterline. I intended to fix the frames on the inside and/or outside with battens. But due to the different chamfering of the frames, it was almost impossible to get that batten neatly on the waterline and cutting the batten would result in different thicknesses. And I would have to expand the waterline again on the battens. A lot of work that did not ensure success. Decided to go straight to sawing.
When everything was checked for the 3rd time, the saw was set up:
I had bought the Japanese Kataba saw for this a while ago. With enough space to be able to make supported pulls. Because the teeth of a Japanese saw are "on pull".
Also double check the alignment of the saw:
And no turning back:
For the photo, I let the saw hang loosely. You can see the flexibility of the blade. When sawing, I let the blade be guided by the two profiles.
Through the first 3 frames:
Phe phoe ..... exciting ……..
I'm still sawing through the frames and the keel. As soon as the saw is also visible on the inside, I'll come up with an update.
DON'T DO THIS TO ME !!!!!!!The Dutchman has gone mad! It has finally happened!
Yep, it gonna happens.Wow! I real nail bitter for sure...I wish you success my friend!
I thought you might have some frames removed on that side, but I had no idea you were going to cut the ship in half!![]()
You do have your work cut out for you...pun intended!Yep, it gonna happens.
And the plan is, you can put them later also back on each other whit a little gap. Some special thing with the rudder and a lot of other things to think about. LOL!
They have. On top in the jig and on 2/3 on the bearing beams.The upper frames will need two areas of support, upper and lower...which the deck beams will provide.
