Faring everything out in all three axis planes is essential for smooth surfaces/curves. File and sand and then step back to look at the model from as many different views as you can. That will bring out items that are not obvious or visible from other directions. It is hard to go slow and patiently as I well know and have had to back up several times for prior rushes. Rebuilds are a pain in the transom!!! I am now doing my third set of foremast shrouds/ratlines as the prior two were not acceptable for what I wanted. Some Swedes are slow learners it seems and that is too much of my ancestry. Rich (PT-2)Yes, I feel the fairing effort is going to be an interesting phase for me. The foremost half of the false deck certainly does not have a true curve, but a series of three distinct edges, a bit like one half of a hexagon so to speak. I'm not sure why AL cut it this way as the long bulwark strips will surely only lie flush against a smooth and continuous curve? One of the forward frames also lifts the fore deck a little higher than it should it one spot, giving the deck a slightly wavy effect. I'm hoping I can get away with this, but I suspect I'll need to do some or other modification there as well![]()
