- Jan 9, 2020
Fine job on the planking Jan! You mention filler - DON'T! Rather create copious amounts of sawdust from the scrap pieces of wood and mix that with your PVA. Then use this mixture instead of filler where required. When properly dry (24 hours) sand as you would have done. Repeat process where necessary. Then, pull closer the PC and see if you can find Flugger (with an umlaut on the "u") primer (for interior finishes) in the USA. If not, order it. The primer is a Danish product. You will very glad that you did!
As to the deck planking, let's hear what the others say, but categorically, no Sharpie!
