Cool!
Looks like concrete and if not a second guess would be stucco which is made with portland cement which is just as good a protection as long as it has a good substrate mesh to help secure it from expansion/contraction with temp. changes. I like the implied quoines and keystone above the lower openings making a substantial base/foundation for the upper portion. RichThe lower windows…they are inset and need to be leveled (angle to wall).
View attachment 256975View attachment 256976
Then the boards to simulate the pattern on the lower tower and around the windows. It will be a lot of boards and a lot of work…but isn’t that how this goes…lol.
View attachment 256977View attachment 256978
Then I painted to see what it’s going to look like. I am excited, once I start dry brushing the white on, it’s going to come alive. But that will be after I finish construction.
View attachment 256979View attachment 256980View attachment 256981
Pic for reference…
Thank you Henk. It’s actually a fun project! A lot of tedious work, but that’s model building.Cool Dean
Thank you Heinrich! I think the truth is I wanted to build a lighthouse. And this was an excuse…lol.Of course it's model building and I like it a lot. Apart from the beautiful work that you are doing, it does offer the kind of add-on to the build which I can appreciate. Even though it will add greatly to the overall visual appeal of the total picture, it remains a separate entity from the model. Both can be appreciated and enjoyed in their own right.
Thanks Peter! I still have to finish the boards around the base, then add a skirt or roof around the perimeter that will have a pitch, and below that is another piece of trim.You are making good progress with this build. The walls really come alive with the door, windows and beautiful vibrant base. I'm curious how you approach the skylight.
Thank you! No need to have a 3D printer! This is a complete scratch build, using plans I created!I really really like your work Dean. I was thinking about generating plans to make this completely from wood. I do not have a 3D printer.
Wonderful work. Thanks for posting this!
You have a true engineering command of the geometry and math for this "carptentery" Well done!Someone asked me how I made all of the miter joints on the boards around the base of the lighthouse.
If I am using a miter saw, I usually have to get my angle finder and measure the included angle of the corner. In this case with an octagon, that would be 135 degrees. Divided by 2 and you get 67.5 degrees per board, therefore each board end would need to have 90 - 67.5 = 22.5 degrees removed, leaving 67.5 degrees each. That's in a perfect world, so the reason I use an angle finder is that each included angle will vary, some may be 136 degrees, 138 degrees, etc... and each time it is a different angle per board, per corner, that will result in a perfect miter joint.
But these being very thin boards (veneer) and on a model at a tiny scale, and finally me having to resort doing it by hand, I chose the following method I will share with you.
First I glued on a board at the width of the side (the width changes as you move up or down being a tapered octagon!)
As shown above, this results in the board looking like it is too short to miter.
But I then file the end flush with the adjacent surface shown above.
Now I have the above shown corner.
Then I glue a board on that adjacent surface as shown above.
Now I file the end of that board flush with the adjacent board as shown above.
And finally I have a perfect miter joint as shown above with no gaps, regardless of the included angle!
Since it is going to be painted, and the boards are so thin (veneer) and small, this was the best approach in my opinion.
Try using a miter saw or measuring the angle on a 3mm x 1mm board...lol![]()
RichThank you Rich, the above method requires no math, no miter saw and no angle finder.You have a true engineering command of the geometry and math for this "carptentery" Well done!Rich
So, it looks like the A-team was also here, Dean.Someone asked me how I made all of the miter joints on the boards around the base of the lighthouse.
But these being very thin boards (veneer) and on a model at a tiny scale, and finally me having to resort to doing it by hand, I chose the following method I will share with you.
Math is why I ended up being an orthodontist (no math needed)So, it looks like the A-team was also here, Dean.
‘I love it when a Plan comes Together’.
Good consideration in advance, saves work and gives a nice result.
And your ‘degree-reasoning’ reminded me of my math lessons from early on. My favorite subject at school.
. But I am pretty good at visualizing things in 3D so I, too, can appreciate Dean's approach.Never liked the math (and still), that's probably why I didn't end up an orthodontist (even no math needed)Math is why I ended up being an orthodontist (no math needed). But I am pretty good at visualizing things in 3D so I, too, can appreciate Dean's approach.
