Build Log "CAF" HMS Enterprise
Folks, began working on the deck knees today, had been waiting on a response form Tom at CAF on the notching of the vertical knees around the Deck Stringers. As u can see in the first image, the plan for the parts in red, show these to be notched, however they have not been laser cut, so these must be done manually. There are 48 on the main deck. This will slow the process a bit. Also Im now seeing how critical it is for the frames to be 100% in the correct place coming out of the jig.....so.....a bit of fine tuning will be needed as I install the horizontal knees
Im not happy with the knees, I need to slow down, and fine tune more. It will be a shame to cover all this detail with deck plank however
Maybe it would be better to wait with the installation of the next beams and carlings until you have finished the knees at the last beam?
With this you have a slightly better possibility to reach out the correct area - our fingers are often thicker than the space between all the timber.
I mean the order something like this:
beam 1 - knees 1 - beam 2 - carlings 1+2 - knees 2 - beam 3 - carling 2+3 - knees 3 and so on
Mates, much better success with the knees over the last few days, all vertical and horizontal knees are now in, lots of sanding to do to get everything nice and smooth and flat, and remove some glue stains. For those of you building this kit, I would take Uwek's advice above and complete 1 section of deck, beam to beam, ie: beam 2 to 3, then 3 to 4, etc....working bow to stern, including the knees and carlings, matching each section to the plan. I actually followed the CAF plan which was to install all the deck beams first, then all the carlings, and finally the knees. Yep, you guessed it....1 deck beam slightly off becomes a big headache.
Today added the stringers running port to starboard between the carlings, (any one know what these are called), from Midships to Bow, and gave a light sanding, next will be Midships to Stern. Actually a learning experience today, as I was looking at progress so far. I should have marked the center of all the deck beams to ensure they were perfectly aligned front to back. I will do so on forecastle and Quarter deck.
not too much today, starting to detail out steering gear and rudder for installation. On the cast brass parts, ie hinges, what is the reccomendation? Brian tumbled his, and then used Brass Black....I dont have a tumbler.....
In addition to what Brian said, I would suggest giving a bath in the white Vinegar for 10~15 minutes (depending on the parts). If you can find 30~40% vinegar, even better.
960188647
