**VIEW THREAD HERE** |
Indeed, “Steady as she goes”Slow and steady and eventually ... we have a beauty!
I used white card stock on the back of the bends and left it there for further support down the line. This worked very well too.Bumblers Notebook Page 3: The Boiler Deck Structure
The instructions,
“Assemble the bending jig for parts 84 as shown on the plans and let dry. Parts 84 P/S have laser engraved vertical lines forward where a bend is required. Their purpose is so that the basswood will yield at these lines when bent but not break. Because of the variance in hardness of basswood and the settings of the laser machines the engraved lines may or may not be deep enough to allow the wood to yield nicely when bent around the bending jig.”
It took a few passes with a new #11 blade to score the vertical lines enough to allow for the bending of the part in the bending jig. I placed a piece of heavy duty masking tape for backing in that area. (Just in case I got carried away).
The bending jg.
The first section came out fine, the second was a little problematic but the backing tape held it all together.
The first section.
The second section in the bending jig.
The time consuming step is placing the 1/16 inch square Battens. There are a LOT of them.
The start of the 1/32 inch square Battens. One per scribed line.
Jan
Do you have any “tricks” for doing the “battens”?I used white card stock on the back of the bends and left it there for further support down the line. This worked very well too.
Yikes!! Good luck with the disassemble.Bumblers Notebook Page 5: The “OOPS” moment
This morning I thought I’d do a dry fit of the Boiler Structure before I started gluing “Battens” again.
I temporarily clamped the Stern and Bow sections of the structure in place on the Boiler deck. As per the instructions I had added 1/8 inch square pieces to the deck to support the bottom edge of the structure. Next I placed the Port side of the structure and noted the fit. Close enough to be used as is. Then the RO-OH moment. The Starboard piece was too long. The forward curved section extended too far towards the bow.
Hmm, it took a moment to figure that out.
My Bending routine for that piece was one bent section short.
Since I had glued in the the “bend braces” (parts 84A on the plan ) I now had to “CAREFULLY” unglue them. So it’s off to do something different while I mull over my “OOPS” moment.
Jan
I managed to get the pieces apart with very little damage. I think if I had used CA I would have been in real trouble. The Titebond II glued pieces come apart pretty easy with the application of very hot water to the glue joints. So it will be RE-DO time in the morning.Yikes!! Good luck with the disassemble.
A little bit of cut and fit at the bow end of the deck is needed, but I think it will look much better than the scribed planks. Those deck joints will "disappear".I'm glad the "goodies" arrived and that you can continue. The planking is looking good!
Peter,You made a good choise with the contrasted wood! Looks very nice, Jan.
Haha .... a smart solution. And the ship increased in value .....Bumblers Notebook page 8: Planking the Boiler deck.
Finished planking Boiler Deck. Now I need to square and round edges of the deck before applying the cap rails.
BTW: I contrived a new modeling tool. I needed some small footprint weights to hold the planks until the glue set. Filled a half dozen pill holders with coins from the “Swear” jar and ……..
Worked like a charm
Jan
