Janos,Looks good! Don't forget to turn the chimney forward! (As it is shown on the AoS drawing too)
János
decided to switch gears for a bit dry fitted frames 1 and 2 to the stem. glue stick pattern to maple board 1/4 thick rough cut on band saw then final shape on my drum sanding station on my drill press
View attachment 220955View attachment 220956
Hello, I am a new member and I intend to start building the Bounty following what you have done. I would like to have some info about the availability of the related drawings of all frames as shown in these yr photos. I acquired The armed transport Bounty of John Mckay but there are no details on the singles frames. Could you help me on how to get them . Thanking you in advance.decided to switch gears for a bit dry fitted frames 1 and 2 to the stem. glue stick pattern to maple board 1/4 thick rough cut on band saw then final shape on my drum sanding station on my drill press
please email me and i will try to help you out..........lesterpalifka@gmail.comHello, I am a new member and I intend to start building the Bounty following what you have done. I would like to have some info about the availability of the related drawings of all frames as shown in these yr photos. I acquired The armed transport Bounty of John Mckay but there are no details on the singles frames. Could you help me on how to get them . Thanking you in advance.
Hallo @lesterpalifkaStarting to build the HMS Bounty. I have started to cut the frames out I currently have 18 Frames roughed out out of the 42 required.
I bought a steam generator and built a steam box to steam the planks for bending. I also bought a thin rip jig for my table saw to mill my own planks.
I had to make a zero insert for the saw as Skilsaw doesn't make one for this model saw which i just bought 4 months ago. I set up a frame roughing station
to rough out the frames. So now it starts. I will need plenty of advice and help on this so i plan to keep this thread going...Thanks in advance. you know what has really helpd me in my modeling has been my work on the Morgan restoration.......
Thank youHappy Birthday!![]()
thank youHappy Birthday!![]()
. Been busy with this and also drawing plans for a 1/20 scale Orca from jaws for a friend of mine. a pic of the plans attached
