A POF model like this is a learning experience for me and I will watch this like a keen student.Hi gang,
I have jumped back into my Granado build with much vigour. Not really much to see in regards to photos, but assembling the frames one at a time.
I am finding this a very enjoyable experience. Its a bit like assembling a jigsaw puzzle.
The frame sections need to be identified and cross referenced from the instruction manual and numbered on the timber. Everything is clearly itemised for ease of assembly. The instructions are in English and very comprehensive.
Anyway this is my assembly workbench.
.View attachment 261058View attachment 261059
Awesome thanks. Im anxious to get it orderedHi Dave,
sure thing I would say you could do this model. I built the CAF Enterprise as my first plank on frame kit and the instructions were not as good as the Granado's.
Its summer overthere Brian is enjoying his fishing and most probably the bbq.Unfortunately you show us very rarely some progress photos of your work, the last one are now already 2 months old.
So maybe it is time for some new update of your model? Please !?!
It's the beginning of winter here. I could go for some bbq.Its summer overthere Brian is enjoying his fishing and most probably the bbq.
In the middle of our summer, I like working inside in the shop as it get near 100 F, and humidity in high 90 percent.
You can break a sweat just walking out to the car to go sosomewhere.
Ok, so I saw the instructions at CAF and just what I thought they did and I do not really see that much of a problem now. They are inserting the PIN(s) from the side of the frame(s) instead of point up and down which would have been totally difficult to get an alignment. You can see that they are in fact inserting the pins from the sides of the frames and NOT glued in - I assume that you already know this. However, I assume that to keep from having the "Joint teeth" showing after separation, that the joints would need to be sanded down all flat. WIth that technique the model pretty much would need to be confined to being displayed as a split all the time.
