- Jan 9, 2020
It is indeed a fine model Jan, but as you are pointing out, certainly a challenge.What fine looking model. Way above my skill level.
Jan
Jan
Nice to have a flexible, flush-cutting saw. Its coming along nicely!With the Admiral at home this morning, I could ask her to take some "action shots" which would explain why Bulkhead #7 was left intact yesterday and the role that it plays.
First off the front of Bulkhead #7 has to be very clearly scribed onto the inside of the bulwarks.
The reason for that is that the inside of the bulwarks will be double-planked (in other words, it will also be planked on the inside) and the line that I have scribed will be the point up to which the planking needs to take place.
Then the Kolderstok saw is called into action. Note how the flexibility of the blade allows it to lie absolutely flat on the deck, enabling the user to make absolutely level cuts. And as @Philski Phil has observed, it is a "pull-action saw" only.
Now all that is required is a little back-and-forth wiggling ...
And Voila ... we have one perfectly-removed bulkhead. The reason why I have obviously removed them now, is because I have to complete the deck-planking and the longer I wait, the more difficult it will be to get the blade into position between the bulkheads and the already-planked areas.
And oh ... by the way ... in case you wondered ... I am wearing what I call my "working pajamas" - when it is below 0 degrees Celsius, I deem it to be ridiculously cold for this South African!
And now, on with the deck planking!
It's a very nice little saw, Phil. The deck planking is going slowly - around the curves, each plank has to be cut and shaped individually. That is the one drawback of a deck that cannot be planked before the hull planking takes place.Nice to have a flexible, flush-cutting saw. Its coming along nicely!
Good Morning Heinrich- 0•C don’t know how you do it- Cape Town winters are bad enough. Great action shots and those angles really show off the beauty of the WB. I agree with all the previous comments- you have done extremely fine crafting thus far. You are converting some guys to Dutch ships through this build I have noticed. CheersWith the Admiral at home this morning, I could ask her to take some "action shots" which would explain why Bulkhead #7 was left intact yesterday and the role that it plays.
Nice action shots Heinrich,With the Admiral at home this morning, I could ask her to take some "action shots" which would explain why Bulkhead #7 was left intact yesterday and the role that it plays.
Thank you very much Grant. I am happy with the progress thus far, so no complaints there. However, there is something that I want to point out on the deck.Good Morning Heinrich- 0•C don’t know how you do it- Cape Town winters are bad enough. Great action shots and those angles really show off the beauty of the WB. I agree with all the previous comments- you have done extremely fine crafting thus far. You are converting some guys to Dutch ships through this build I have noticed. Cheers
Thank you Stephen. Like @Dematosdg Daniel would say: "A picture says a thousand words"!Nice action shots Heinrich,
I would also have to say that little saw looks quite handy.
As for 0 degrees C, I would definitely agree that is a bit chilly.
Cheers,
Stephen.
Heinrich once those are in you won’t see your irritation. I think Hans (and your experience) worked in this factor and the deck planking after the bulkhead removal. On the Mantua Victory, following instructions, I planked deck first and now there are two (one port one starboard) slightly showing. Experience and planning counts for sure. Will have to find a barrel on rum to cover. CheersThank you very much Grant. I am happy with the progress thus far, so no complaints there. However, there is something that I want to point out on the deck.
Despite my best efforts I could not get the planks to butt up perfectly against the bow as indicated by the blue arrow. They are as tight as they can get, but they do not follow a perfectly symmetrical line. Under normal circumstances this would have irritated the living daylights out of me, but please see the pic below.
The area indicated by the yellow lines will receive an inner planking as well at a later stage which will automatically correct that irritation.
Grant, you are right. Trust me, I have already checked - otherwise I wouldn't be able to sleep tonight.Heinrich once those are in you won’t see your irritation. I think Hans (and your experience) worked in this factor and the deck planking after the bulkhead removal. On the Mantua Victory, following instructions, I planked deck first and now there are two (one port one starboard) slightly showing. Experience and planning counts for sure. Will have to find a barrel on rum to cover. Cheers
Thank you very much my dear friend - your kind and complimentary words are most appreciated. Dankjewel mij vriend!Prima vakmanschap Heinrich, mijn vriend
Excellent craftsmanship Heinrich, my friend. She is looking beautifull.
Very nice looking model, except for the stern. I just can't overlook it and I'm very inclined to use a nickname from an old WW II bomber, known as big a.. bird... No offense though, from the looks of it, a complex build ánd a beautiful reflection of the Dutch rich seafaring history.Wow Daniel - that is high praise indeed, my friend! I love the lines of the WB but I have often thought that maybe it's case of "beauty is in the of the beholder". It is therefore very gratifying to hear that so many of our members share that opinion. I am also very pleased about the natural color of the walnut-covered hull.
About the Fluit - I know that Hans is now adding final details, so it will not be long now before it becomes available. In the meantime, here are two of my favorite pics of the Fluit for you to enjoy!
Hello Johan - which stern are you referring to - the Willem Barentsz or the Fluit?Very nice looking model, except for the stern. I just can't overlook it and I'm very inclined to use a nickname from an old WW II bomber, known as big a.. bird... No offense though, from the looks of it, a complex build ánd a beautiful reflection of the Dutch rich seafaring history.
This is definitely not a build for the faint hearted or the less than very experienced builder.With the Admiral at home this morning, I could ask her to take some "action shots" which would explain why Bulkhead #7 was left intact yesterday and the role that it plays.
The Fluit, the WB lines are, at least to my eyes, more pleasant to look at.Hello Johan - which stern are you referring to - the Willem Barentsz or the Fluit?![]()
Thank you very much Johan - trust me you are not the only one who is in sometimes and awe and horror!!!This is definitely not a build for the faint hearted or the less than very experienced builder.
I can't suppress a feeling of admiration, awe and horror when I read through your log. Keep your surprises coming.
Once visited Shenyang midwinter. Only had Dutch wintergear with me and temps dropped to minus 15*C...
And I suppose it's extra bad if it is the builder who experiences those emotions!
The Fluit, the WB lines are, at least to my eyes, more pleasant to look at.![]()
Oh boy, we’ve been at 0 or below to 4 degrees F, every morning for the past week. (-17 to -15 on your C scale). 0 C (32F) would be a heatwaveYes, China can be bitterly cold during the winter - and obviously it gets considerably worse the further you go north!
