A small update from the past few weeks. I have finished the bulwarks but not without some redo’s, especially for’d. I also changed the look of the transom, as discussed in the last few posts.
For the bulwarks I cut 1/8” x 1/16” alaskan yellow cedar strips from billets. The wood is a delight to work with instead of basswood. However, I wasn’t satisfied with my initial attempts at trying to line up all those 1/8” planks with the gun and sweep ports. Suffice to say I stripped and redid pieces where necessary. A few times.
Nevertheless, the planking is done and I started on the first very thin coat of Vallejo primer. For those of you who read the discussion, on a different thread, about ship paint colours you will know there are many opinions on what is correct in times gone by. The grey primer is, of course, not the finished colour for the Syren. I will be brush painting those inner bulwarks with what I now call a “Hue of Heinrich”
- yes, red. This is the colour the designer, Chuck Passaro, used and recommended as did Heinrich and many other modellers.
I had previously left the transom piece aft as a blank canvas in line with the Syren manual. In other words no planking in that area. This was discussed in the last few posts. I knew I had insufficient depth in that area for adding 1/16” thick planks so I cut strips down to some insane thickness hoping I could work with them. There was no problem cutting to the correct 1/8” width. However, I had a heck of a time trying to curve those by now very thin planks longitudinally for the subtle curve of the transom. So I used a thin laminate of basswood, made a gently curved and sized plank template and then scribed simulated lines onto the laminate. Once stained it matches the upper hull strakes reasonably well. I’m still not happy with stained basswood, it’s blotchy, but hindsight is a wonderful thing. That area needs some cleanup.
So that’s all for now. I will be brush painting the red next then back to the books to read up on deck planking arrangements. Thanks for checking in on me, those likes and comments are always well appreciated and very encouraging.
