Learned a few things about working with the Mohagony supplied in this kit.
Dry, it's brittle. It will bend a little bit but likely to crack or snap.
Bending it dry with heat works but I didn't like this method.
Wetting it for a few minutes then using heat was better for me as the plank would begin to bend just as the water evaporated giving a visual clue.
Soaking for an extended time, at least a few hours to overnight,gave good results. Would bend easily with heat.
The best results were to soak an extended period of time, then bend entire plank with heat as shown above. Next soak again, 15-30 minutes. The plank was then very flexible if worked slowly. Tighter bends could be accomplished by repeatedly soaking and using heat. The iron I'm using is at 325-350°F.
Glenn
Glenn
