**VIEW THREAD HERE** |
Nice rendition! It makes me wonder, with some cannon and mortars being cast with iron, what did they see for rust and oxidation at sea.I made for me a very big step and painted some elements red - usually I like it more to have everything, even the wales, in the original timber color - but with this section model I tried it first time - and I am still not sure, if I like it.......
Maybe it is also because usually I build in pear, Elsbeere or cherry but now this section model is boxwood, which has a much lighter brown colour, slightly going into yellow. So some contrast is maybe not so bad ...... but take a look .....
and I am trying to show also the striptease, which was necessary to make the morter Ready for action with dismantling the roof and pit elements
the two roof elements received their eyebolts for lifting
with the help of tackles and a yrad-arm the elements were dismantled
covers of the side elements were layed on side - I guess here were the tackles for the mortar stowed
It is getting already growdy on the deck
the pit bulkhead frame was also lifted away
now also the small girders and the two inner bukhead walls away - after installation of the tackles (still missing) the mortar could be turned
BTW: the last photo is showing more or less the real colours (the other photos are much lighter (and colder) because of the articial lights in the workshop) - so the red is not so pinky
Imagine how crowdy it was on the deck, you should add here in addition the four "normal" guns, somewhere were also the oars stowed, spare anchor etc etc.
Maybe they dismantled these pit elements and stowed them on the tender ships, which were delivering the powder and the amunition......
Hello Uwe, I do like the cover on but opened. I don’t know if you can loosely fit the cover so when you feel like it you can take it off and adjust the mortar? Best of all worldsFor later on I have to decide how to present the section model.
With closed or semi-opened mortar pit
- or completely open and dismantled elements so that the mortar is ready for action, but than maybe also with the necessary tackling of the mortar
it is time to finish all the missing deckplanking
After that the outer hull planking is the next main task .... to be continued .....
Hi Uwe. You asked it to Maarten, but I have used it on the inside of the bulwark and stanchions. You need several layer to get to get an opaque layer.Until now, I did not try the bottle with "white" No. 100 which could be interesting for immitation of the "white stuff" painting of the underwater hull - with a little bit gray it could look good - @Maarten did you made already a test here?
Hi Uwe!
You, like me, were supposed to build the whole Granado. Then one mortar could be exposed and the other semi-enclosed.
Radek
Hi Uwe,Based on the interest I checked the Talens Ecoline web-page - they have together 60 different colours available
the bottles:
View attachment 290731 View attachment 290732
Ecoline ink | Official website | Royal Talens
Ecoline liquid watercolours have been known for their brilliant colours since 1930. Discover the 60 bright, vibrant colours.www.royaltalens.com
and the brush pens
View attachment 290734 View attachment 290735
Ecoline brush pens | Official website | Royal Talens
Create beautiful flowing and vibrant lines with the Ecoline Brush Pen. The Brush Pen is known for its flexible tip and 60 brilliant colours.www.royaltalens.com
I still have different aero colors on the shelf here. I'll experiment a bit with that too. Especially if it holds the color better. Thanxs for sharing!Schminke aero color are pigmented inkts but give a more opaque result with less wood grain visible.
Hallo Daniel,Uwek,
You pass the ecoline pen all along the plank border PLUS you glue the plank with blackened glue using liquid ecoline from the flasks or blackened with graphite ?
The ecoline ink, when passed along the plank border, does not enter by capilarity creating like small hairs/filaments (forgot the English word) ?
Or you seal the wood pores before using the ecoline pen on the plank border ?
Sorry for all these questions
Thanks
Daniel
