Breathtaking...
Thanxs, Paul. Please, Keep breathing ......Breathtaking...
Marvelous, just marvelous...Thanxs, Heinrich. These are much appreciated comments. Indeed very busy today, with special for you in this reply on your post:
The last contribution for today.
After the ink has dried, time for the linseed oil. When that was also dry, this showed up:
Also taken outside for the 'exploded-view':
The profile of the section above the waterline:
Not very clear in the photo, but the treenails also shine through here. Mission accomplished.
Some extra attention to the stern. We already had some discussion about planking the stern first and then the planking of the hull. And I just did it the other way around.
I came across some pictures of the BN-II and the original BN. Especially with the old ones they show a solid edge around the stern face. Would they then.......
That's why at my stern on the natural starboard side a heavy edge over the side of the stern planks.
A little stubborn is okay with me. Otherwise ...... AL-FI.
For now, I sit back, rest and enjoy the view on my BN.
Absolutely great
Thanxs, Johan & Jan. Sometimes the progress is slow, but once the preparatory work is done, you can suddenly take big steps with a high visual impact.Marvelous, just marvelous...
Thanxs, Uwe. I appreciate it very much. The Ecoline, but also the Aero Color, are a eye opener.Your hull is looking great - I am happy, that you had also a good experience with the ecoline colours
You haven chosen the correct "red" for this purpose
I am a big fan of your model and hope to see it once in real
Remarkable work PeterThe 2nd inserted plank also succeeded:
And immediately proceeded to close it.
And the lotal picture 'on the waterline' with the drill holes already marked:
Not sanded much yet, so the dirt from pressing etc. is still there.
Lots of trennels to go!
This remains a fascinating build Peter. I can't wait to see the finished product of course, but the journey there is a privilege to observeThe warthog finally has its load complete:
Almost 2500 screwed in on this side.......
Before I can sand this side of the hull smooth, I first applied the waterline strip:
This protrudes slightly over the edge and will be sanded into shape.
Now that the seam is filled, I can adjust the seam:
I had to put a small insert in 2 places. They'll go with the sanding soon.
Now it's coming to life!Exciting!!! I couldn't wait: the first layers of Ecoline Carmine Red:
Now has a matte appearance.
The treenails remain visible:View attachment 292497
Let it dry for a while before we continue with the layer of Linseed Oil.
Absolutely superb, the recognisable Bluenose is starting to emergeThanxs, Heinrich. These are much appreciated comments. Indeed very busy today, with special for you in this reply on your post:
Thanxs, Maarten. Thanks to your posts, and the others who start using, I was drawn to the use of this 2 kinds of ink. Sometimes the Ecoline works fine, but the Aero Color also. With the accent differences and color tones.Fantastic work Peter,
She looks just perfect.
Remarkable work Peter![]()
This remains a fascinating build Peter. I can't wait to see the finished product of course, but the journey there is a privilege to observe![]()
Thanxs, Mark, for sharing my journey through my panking, sawing and painting adventure.Absolutely superb, the recognisable Bluenose is starting to emerge![]()
Thanks, Piero. That picture is new for me. Nice to see.
Thanks and correct, Dean. I made some changes to the top of the blade.Looks great Peter!
The biggest problem with the YQ drawing, is the height of the rudder, it couldn't turn regardless of what shape the rudder shaft is!
It needs to be lowered to clear the hull. I see you have that covered!
