Imperial yacht Uvalen by Falconet in 1:48 [COMPLETED BUILD]
The glazing is ready. I'm not really happy with it, but the job is done.
Next in turn is the protective metal grating. The Deluxe version of the kit contains it by default, otherwise you can buy it as an option. The simple version contains a resin grating.
The first step - a special template for assembling and the central part. Now I'm plucking up the courage for a lot of pinpoint soldering.
What did you use for the glazing on the skylight?
I have seen those who use microscope slide glass lids, which are very thin for this task in other hobbies.
you are on a good way with the metal works - I am looking forward to see the final result....
I PRAY TO MY LORD AND SAVIOUR JESUES CHRIST THAT IT ENDS, A WAR AGAINST BWOMEN, CHILDREN, THE EDERLY, THE SICK IS TOTALYY UNGODLY ON THE NAME OFN JESUES THE THINGS GOING ON ARE REAL NOT PROPOGANDA ON HIS NAME I AM NOT LYING. PLEASE LORD SAVE THE INNOCENT IN YOUR NAME JESUES DON
That looks great, Walterone! I use a ceramic sharpening stone to remove burrs from photo-etch. You might find that helpful for smoothing down the ends of the brass rods flush with the frame.
Well, the grate is ready. I'm not very happy with it, but I'm so happy that it's finished :) Maybe some day I'll make another one. It's been not an easy job, for an unexperienced modeller it can be a real challenge. But the resin grate is a good alternative, I think.
Good evening Walterone, the metal grill you made is a gem, the resin one has nothing better than yours, congratulations
