, VA 23606
Very clean work, as always. The video has given me valuable tips for building rudder hinges, as I want to redo the old ones on my Serapis.
Thank you very much!Very clean work, as always. The video has given me valuable tips for building rudder hinges, as I want to redo the old ones on my Serapis.
One question that has been bothering me for a while: were the hinges blackened on coppering or brass colored?
Christian
My pleasure! I'm glad you liked it!Very good and informative video - many thanks for showing us your techniques
Thanks for sharingHello Mark
I am glad if my construction will help you! Fly is a sister ship of Pegasus, so they are identical. The only thing that the manufacturer decided to paint the hull below the waterline instead of copper plates...
My threaded rods pass through the keel and enter the hull at 35-40mm (the length of the drill). Usually I stick it on epoxy but Pegasus is a very small and light model so I just used a thick CA glue when screwing the rods into the wood...
I used CA glue (gup filling) - I showed the bottle in the video, somewhere in the middle of the issue...What kind of adheadive are you using on the copper panels to help them from curing before final adjustment?
en.shipphotographer.com
